Old 08-11-2004, 07:23 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Question Which Starter Do I Use???????
I have a 153 tooth flex plate. I know that there is two different starter, one that works for my application and one for the larger flex plate. Which one do I need and how can I tell them apart?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 08-11-2004, 07:26 PM   #2
crazy longhorn
Fabricate till you "puke"
153 t flex, straight across bolt holes.....168 t staggered bolt pattern on the starter......the block has all 3 holes
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-11-2004, 07:36 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
Thumbs up
Crazy Longhorn
Thanks, that just the info I needed.
Old 08-11-2004, 07:59 PM   #4
john
member #16
john's Avatar
While were on the subject, anyone know which application uses 153t or 168t?
Thanks John
john is offline   Reply With Quote
Old 08-11-2004, 08:48 PM   #5
kaycee
kaycee's Avatar
Talking
I have found on all my 327 they were the 153 T and the 350 has all had 168T so on my 69 stepside I put in a 327 with a 168t and a 350 starter (staggered) works great, the straight across pattern won't work (Yes I tried) difference is the nose cone on starter.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-11-2004, 11:06 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I was wondering that same sort of question John. I always thought that the BIG clutch (11 & 12") models would use the 168t flywheel/flexplate. I do know that I've seen a lot of bigblocks with the 168t flywheels/flexplates. I propose that EVERYONE on this site go under their trucks right now & check! JK!
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
