Old 08-11-2004, 08:43 PM   #1
patgizz
patgizz's Avatar
what to do about needing a longer driveshaft
so my pig originally had a 700r4.
i have a brand new th350 w/ 6" tailshaft that i have to/want to use. this is about 3" shorter than the original 700r4.
the truck(burb) has a 2pc driveshaft with carrier and slip joint. i need a longer front half of the driveshaft. how do i go about that? i know i could have one made but thats a ton of cash right there. last time i had a shaft made with my original ends it was $300 and that was 6 years ago.
is something like a crew cab longer in the front half to have shortened, or were the fronts all the same and the rears were shorter/longer?
1968 C20 292/sm465
1990 C3500 dually 454/th400
1991 sonoma 4.3/700r4
1994 K1500 burb 350/4L60e
1954 belair, 1991 corvette, 1972 chevelle, 1995 LS swapped impala SS
patgizz is offline   Reply With Quote
Old 08-12-2004, 03:26 PM   #2
1986Silverado
What I drive
1986Silverado's Avatar
We have a shop here locally that all they do is work on drivelines...matter of fact part of their name is Powertrain. I had a driveshaft shortened about 6 years ago and it was shortened, balanced and had new u-joints installed for $85. You should have a shop locally that could handle the task without having to build a whole new driveshaft.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 08-12-2004, 03:33 PM   #3
Destructo
find a different shop, have the shaft re-tubed a little longer should be no more than around 100 bucks. Thats really the only way to get around it I think.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
