Wheel bolt pattern
Does anyone know what the wheel bolt pattern of a '97 Nissan two wheel drive pickup? Is it the same as our '72 5 bolt pattern? I have an opportunity for some custom wheels, but don't know if they will fit my '72.
Thanks Don
Thanks Don '57 Chevy Nomad '70 Buick GSX '72 Cheyene (Boys' truck) |
Cantankerous Geezer
My understanding is the bolt pattern is the same, but there is more to check. The center hole should be the same size, especially if you haul any loads. You also need to check the backspacing and/or setback, which determines where the tires sets in and out. Also, if you have disc brakes, you need to be sure they will clear.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
