08-12-2004, 05:28 PM | #1 |
cuting firewall
Hello,
I need to cut out some of the fire wall to accomadte a new engine. I could probably leave it alone, but if something ever happened and I needed to remove the engine I would hate to find out things are too tight. what if anything do I need to watch for?
Mike K Friend of Bill W |
08-12-2004, 06:53 PM | #2 |
What engine are you putting in?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-12-2004, 07:25 PM | #3 |
Watch out for your cornhole !
Wow, if you have to cut the firewall for engine in one of these trucks, it must be a weird engine combination for sure.
08-12-2004, 07:35 PM | #4 |
Fabricate till you "puke"
The firewall is cutup in my longhorn, but it has run both Olds & Cad over the yrs.....I like em set back as much as possible too! with most of the chev swaps, you shouldnt need to cut the firewall tho.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-12-2004, 11:24 PM | #5 |
Yukon Jack had to massage his firewall to accommodate the BB. Do a search… oh wait there isn’t one.
08-13-2004, 05:14 AM | #6 | |
08-13-2004, 10:10 AM | #7 |
Post Whore
When you cut the firewall, look at where your heater stuff in the cab is so you make sure that won't cause interference. Also look to see if it will interfer with how your gas pedal is situated.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
