08-12-2004, 10:20 PM | #1 |
Howzit?!?
OT Painting steel wheels question.
Okay this isn't really a 'painting' question.. so that's why I'm posting it here instead of in "Paint & Body"
I have four steel VW wheels that I am going to repaint for my bug. They need paint all over, with some special attention to the bead and lip area. The prep work I have done, and the rattle-can paint I'm sure will be fine. What I want to know is... when do I have the tires mounted? Should I completely paint the wheels and hope the tire shop doesn't scrape the paint off while mounting the tires? OR Should I have the tires mounted (but not aired up or balanced) onto the bare wheels... then paint the wheels? Thanks for any help you can give PS: Mike (fine69) I know you said just leave the inside... but after I wire wheeled and sand blasted them... I want to do a good job with them.
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
08-12-2004, 10:38 PM | #2 |
Psycho-billy Member
Most mounting machines have a nylon (?) end that doesn't do much damage to the finish. I'd paint 'em up then have the tires mounted.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
08-13-2004, 09:14 PM | #3 |
Howzit?!?
Thanks Lux!
Any other opinions?
08-13-2004, 10:52 PM | #4 |
hmm...
if you paint them with the tires on, you better make really sure that you don't get ANY paint on the tires or else you've got some scrubbing to do and it'll look ugly if you don't get that paint off.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
08-14-2004, 06:57 AM | #5 |
I say paint 'em first inside and out, and let it cure for at least a week, depending on the type of paint you're using, if you can wait. If they get a scratch or two at the tire shop just touch it up.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
08-14-2004, 07:05 AM | #6 |
Watch out for your cornhole !
I paint all my wheels bare, let them cure for 24 hours, and mount the tires myself.
Use Goop hand soap on the tire bead and you can put them on the wheels by hand, no tools at all.
08-15-2004, 08:41 AM | #7 |
Almost done!
You can get them bead blasted and power coated fairly cheap at some of the major truck tire centers. I'm sure Knoxville has several in the area. Look for a Bandag recap center or a Bridgestone truck tire center. Here in Dallas I can get them done for $15.00 ea. They have different colors, black, red, white and silver.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
08-15-2004, 12:12 PM | #8 |
Howzit?!?
Thanks everybody!
