Old 08-13-2004, 12:39 AM   #1
kdogg
Polished TPI setup
I have everything to make it a working setup except the TPS and coolant temp sensor. They are cheap and available at any parts store.
Included are:
The upper and lower intake and the runners.
Throttle body.
Fuel rail with injectors for a 305 and an adjustable fuel pressure regulator.
Over 30 hours of polishing!
Two wiring harnesses
A '165' computer, The PROM has been tuned.
Distributor with matching coil.
Knock, IAC, air temp, oil pressure, MAP and oxygen sensors.
Gasket set for the TPI and intake to heads.
Looking to get $400 for it. You can post here or email me at Jetski7292@aol.com if you are interested or have any questions. Thanks.
1972 Chevy. Fully restored custom. Air suspension, fully shaved, custom interior.
Check it out along with all of our other work at
www.CeeksHotRodShop.com
kdogg is offline   Reply With Quote
Old 08-13-2004, 05:42 AM   #2
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
I sent you an email. Chuck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 08-13-2004, 10:19 AM   #3
kdogg
Re: Polished TPI
Return email has been sent. Thanks.
Old 08-14-2004, 02:18 AM   #4
kdogg
Up to the top
Old 08-14-2004, 07:13 AM   #5
vtblazer
vtblazer's Avatar
Tpi
Sent you an e-mail also...
vtblazer is offline   Reply With Quote
Old 08-14-2004, 09:57 AM   #6
kdogg
Responded by email. Thanks.
Old 08-16-2004, 03:50 PM   #7
CHEVYE
my gas saver
CHEVYE's Avatar
i`ve had 2 of theses recently. do you have any pics? does it take speed sensor or a mass air flow? also are the runners dented any? thanks, eric.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 08-16-2004, 06:12 PM   #8
kdogg
Re: TPI
This is a speed density system so there is no MAF sensor, which makes it easier to use in whatever vehicle it is put into. One picture of it can be found at http://www.mnfbody.com/attachment.php?attachmentid=148. You can email me at Jetski7292@aol.com for more pics if you would like. I have pictures of everything which is included. As far as dents go two of the runners on the passanger side have flat spots in them. One more pronounced then the other. They are as if something hard and flat pressed against it. In my opinion these could be easily rounded out as was my plan before I decided to get rid of it. If you have any more questions post or you can email me. Thanks.
