Old 08-13-2004, 12:50 AM   #1
traveler44
97 Silverado front brakes
Any advice........
I have a 97 Silverado that needs front brakes.....however the repair shop said I "need" the hubs replaced to the tune of $400 each. He said it is a design flaw by GM. He told me the ABS is sent a signal bacause they are bad that cancels the front braking the last 20 feet. Doesn't sound right to me but I am not that mechanically inclined. Anyway the whole brake job (fronts only) is going to cost me $1000. Hopefully someone out there could offer some advice before I pay for this. Thank you very much.
traveler44 is offline   Reply With Quote
Old 08-13-2004, 02:18 PM   #2
Prop_Washer2
Hmmm...sounds like to me...I have a '98 K1500 w/115k on it, just replaced the rotors, calipers, and pads for $280 at goofy Pep Boys...
Prop_Washer2 is offline   Reply With Quote
Old 08-13-2004, 04:39 PM   #3
patgizz
patgizz's Avatar
i recommend a new mechanic
patgizz is offline   Reply With Quote
Old 08-13-2004, 05:12 PM   #4
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
I agree with the Prop_Washer2. I just put front brakes on my 97 GMC K1500 Suburban about 6 wks. ago. They turned one rotor, purchased 1 Lifetime rotor (other rotor couldn't be turned) and new Wagner pads and it was about $80.00. Calipers didn't need replaced. I did the work in about 1.5 hrs. I'd find a new mechanic...
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 08-13-2004, 07:33 PM   #5
99-2door
99-2door's Avatar
Was your ABS light on in the dash?
Sounds like this guy is full of it. Find somebody else.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 08-15-2004, 11:27 PM   #6
dumpedv8
i have a 97' and these trucks dont really have hubs i thought because the studs are pressed into the rotors! then the bearings and race go inside the rotor!i replaced both front rotors and pads and calipers for under $300 and all are acdelco! (hook up at dealership!!) it shouldnt cost nearly want he wants, get a new mechanic!
dumpedv8 is offline   Reply With Quote
Old 08-16-2004, 01:00 AM   #7
99-2door
99-2door's Avatar
They do have hubs. the lugs aren't pressed into the rotor. You can take the rotor off of the hub assembly without removing any studs.
Old 08-16-2004, 03:06 AM   #8
alf4444
alf4444's Avatar
Agreed I had a big O cross thread a lug nut and in the attempt to remove it stripped out the hub! The replacement cost was a little spendy something like $180 but not $400. I really don't understand houw the hub would affect the brakes Either way brakes are easy do them yourself or atleast another shop. BTW where did you take it? Another BTW is the only gm flaw I've heard of (and expeirianced (SP?)) is the rear brake adjuster freezing causing premature wear of the front brakes caused by insufficient braking in the rear because of this I had my first brake job on the front at 32 k didn't have to do the rears until 100k
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 08-16-2004, 10:49 AM   #9
dumpedv8
ok? thats not the way my 97' is set up. you remove the dust cover, then the axle nut and codder pin, then slide the rotor off the spindle and the studs are pressed into the rotor. i just upgraded mine to a 2500 series brake rotor for six lugs instead of five! both of them are the same....no hub!
