Old 08-13-2004, 01:14 PM   #1
guypm
a/c blower switch...anybody got one ?
Im needing a a/c blower switch as mine will not reach the high speed when in the high speed position. Ive changed the relays and this has still not got me high speed fan. Anybody? Any help appreciated
Guy
guypm
1971 SWB Fleetside/350 performer rpm heads &intake/ holley 750dp/1.5roller rockers/MSD6a/700r4
1650stall/one piece driveshaft/3.73 open/dynomax ceramic coated headers/3chamber flowmasters/
guypm is offline   Reply With Quote
Old 08-13-2004, 07:18 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
While ur at it check the connector. Mine was melted. Do'nt have an extra.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 08-14-2004, 06:15 AM   #3
hanssolo
hanssolo's Avatar
rich, I've had to replace my fan switch itself every 2-3 years. Reminds me of my '92 Chevy van, the rear blower switch burnt out every 2 years also. Just bad GM design. Not enough power rating/heatsinking on the switches.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 08-14-2004, 11:44 AM   #4
mrein3
mrein3's Avatar
I bought a new switch and connector from LMC. Then I rewired it so the high-speed wire controlls a relay that I mounted to the heater assembly under the glove box. I believe too many amps run through the switch on high speed. I THINK they had a relay somewhere from the factory for high-speed but I was converting from no AC to AC so I just did it the way I think it SHOULD be.
Now if I can only figure out a way to stop breaking the top slide selector on the control assembly...
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
