Old 08-13-2004, 03:32 PM   #1
sdmahr
sdmahr's Avatar
WTB: Trans Cooler Lines
I'd like to buy some THM350/350V8 Cooling lines from the tranny to the radiator for my 69' C10 Stepside. If you have some that aren't contaminated, torn up, bent up, or broken, let me know via PM.
Scott
sdmahr is offline   Reply With Quote
Old 08-13-2004, 09:06 PM   #2
MACKL
Almost done!
MACKL's Avatar
I bent my own. I bought the longest stock and used a trick a "muffler artist" showed me, a coat hanger. Simply bend the coat hanger how you need the line to go, then, bend the line to match the hanger. You will have to tweek it alittle when you fininsh but with a good tubing bender, it looks good.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 08-13-2004, 09:31 PM   #3
sdmahr
sdmahr's Avatar
Did you use a standard "flaring tool" to put the flares on the end of the tubing? Where did you buy the fittings?
Old 08-13-2004, 09:56 PM   #4
cochran63
cochran63's Avatar
I have NAPA make high pressure hoses for my trucks. you can run them inside the fraimrails and they look great. For $35 you can't beat them.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 08-13-2004, 09:58 PM   #5
pickupman
pickupman's Avatar
I have new prebent ones in stock if interested.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 08-14-2004, 09:30 AM   #6
MACKL
Almost done!
MACKL's Avatar
RE: Tranny lines
sdmahr,
You have to use a double flaring tool to flare the ends. They are about $20. Heres a link.
Flaring tool
The bender I used is a snap-on, but there are better ones out there now. Here is a link of the ones with the tightest bend radius.
Bender
I did not have to buy any fittings, I had enough of them lying around the shop. (Too many projects), I'm sure your local parts or hardware stores will have them. If you can not find long lengths of tubing, you can buy 2 and put in a union to connect them. They will also come with the fittings on the end,
Good luck with your project. I'll try and get you some pic's later today...Kelly
V8-350
Auto/PS/PDB
Blazer Fuel Tank
