Old 08-13-2004, 03:56 PM   #1
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Mechanical Throttle Linkage
We're about ready to bolt the Quadrajet (yep, I'm one of THOSE guys) on the '69. The carb is the one that came with the SB, '84 vintage.
The brackets, etc. that came with the engine are for a cable-type throttle, and we still have the linkage as pictured below in the truck (tied up out of the way in this pic). The linkage is left over from the I6 setup.
Who has done this hookup already, and what do you recommend? I'd prefer not to go to cable, if that's practical. We're talking straight throttle here - no trans kickdown, etc.
Thanks...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-13-2004, 06:21 PM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
What the hell are those manifolds on there. Looks like you should tilt them babies up and mount a huffer on there.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 08-13-2004, 06:34 PM   #3
stickshift_or_walk
Nothin' special as far as I know. Came on the donor car, an '84 Buick Regal, I think. They probably aren't the best-flowing things out there, but the clearances work well, and the price was right...SSOW
Old 08-13-2004, 08:20 PM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i put a v8 in my I6 truck. i put the motor in the v8 position so the rod needed legthened so i cut it in half and welded a rod in the middle so it was still adjustable at both ends. i have also seen people make one from scratch. i am not sure what they are called but they thread on to a rod and bolt to anything. like a ball joint swivel 90.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 08-13-2004, 10:59 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
I took out my 250 & did the same Qjet-350 swap. what I did was got some 1/4 rod from hdwr store. used a 1/4x20 die & made a new rod to go to carb. make sure you thread it enough for adjustment (about 1 1/2 inch on each end). get a pair of throttle liknage ball-stud swivel assys from NAPA or equivalent(about $8 each)
I would post a pic but I am unable to reduce them down to 100KB.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-13-2004, 11:03 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
about those manifolds, GM came up with those just so they could burn plug wires & cook the valve cover gaskets. but on the good side they dont warp & crack like the under plug log style.
Old 08-15-2004, 09:26 AM   #7
stickshift_or_walk
68C15, that sounds like what I'm looking for. If you'll e-mail the pick to me (PM'd you my e-mail address), I'll resize it and add it to the post. I know it would really help me out...maybe others.
Thanks...SSOW
Old 08-15-2004, 09:48 AM   #8
Mudder
Mudder's Avatar
I'll go out and get yas a pic........
Mudder is offline   Reply With Quote
Old 08-15-2004, 09:57 AM   #9
Mudder
Mudder's Avatar
Looks like it could use a little paint........
