Old 08-13-2004, 07:47 PM   #1
76bonanza
76bonanza's Avatar
Wd-40
Is it ok to soak bolts overnite in WD-40?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-13-2004, 09:28 PM   #2
1972C10
1972C10's Avatar
Why wouldnt it be?
1972C10 is offline   Reply With Quote
Old 08-13-2004, 10:02 PM   #3
76bonanza
76bonanza's Avatar
Who knows seems like when I think something is ok. It never is.
1968 c10
lowered 3" 4"
Old 08-13-2004, 10:23 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
If you're looking to free stubborn bolts, use PB Blaster. It's actually a penetrating catalyst, and works way better than WD-40. Just my $.02, good luck
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 08-13-2004, 10:54 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes it is ok to soak your bolts over nite. Don't soak your nuts over nite though, they might shrink.... :p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-14-2004, 09:52 AM   #6
screwballl
Tonawanda 454
screwballl's Avatar
i work at Ace hardware and i agree totally.. PB Blaster is 1000x better for loosening nuts and bolts and you should only need at most an hour
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 08-14-2004, 11:22 PM   #7
Senor_paco
and if that doesn't work, a dose of "hot wrench" will fix it up. nothing helps bust rusted bolts loose like the expansion from 2000+ degrees! make sure to let them cool a bit before tryign to work loose. sometimes that gives you the edge.
Senor_paco is offline   Reply With Quote
Old 08-16-2004, 03:03 PM   #8
Grim Reaper
WD-40 is like american beer....... Ohhh I won't go there.
WD-40= Water Displacement formula try # 40. It was made for drying out ignition on automobiles and gas engines. Through great marking lies somebody decided that it would be the end all be all to everything from sticking muffins to loosening bolts....it's not.
PB blaster is the shnizle.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-16-2004, 04:32 PM   #9
1972C10
1972C10's Avatar
AeroKroil Is some good chit tooo but its like 10 bucks a can.
Old 08-16-2004, 05:15 PM   #10
BeerMonkeY
sold
BeerMonkeY's Avatar
pb is the best for removing stubborn bolts, however wd-40 works for everthing else (removing oil stains, bugs, tar from truck)
07 Rubicon, 2" lift,35's on some bling'n 20"s, warn winch. (20's for sale, 5on5)
looking for 73-87 crew cab with 8' bed,2wd,PM me if you see one around
BeerMonkeY is offline   Reply With Quote
Old 08-17-2004, 04:54 AM   #11
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I have had real good luck with Kroil
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-17-2004, 08:37 PM   #12
bulky
Bulky
bulky's Avatar
Only 2 tools needed in the tool box
You only need two tools.... Duct Tape and WD40. If it moves and it shouldnt, Duct Tape it.....if it doesnt move and it should, WD40 it!
bulky is offline   Reply With Quote
Old 08-17-2004, 10:32 PM   #13
SanitysBane
if you can't duck it, f*** it!
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 08-18-2004, 08:22 PM   #14
loweredd
www.loweredd.com
loweredd's Avatar
PussBlaster is junk. Kroil is THE best penetrating oil you will ever use. PERIOD.
loweredd is offline   Reply With Quote
