Old 08-14-2004, 10:30 AM   #1
76bonanza
76bonanza's Avatar
Header Ticking
I have had my headers for about a month. And they are really starting to tick sitting at idle with the radio off I can here them ticking I can find no leak. Does this sound normal?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-14-2004, 10:58 AM   #2
1986Silverado
What I drive
1986Silverado's Avatar
Not unless there is a leak.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 08-14-2004, 11:00 AM   #3
rage'nrat638
rage'nrat638's Avatar
Thumbs up
WELL THERE HAS BEEN MUCH TALK ON THIS TOPIC....
#1 GASKETS.....MOST WILL DO....I RECOMMEND COPPER.....
#2 GOT TO HAVE STAGE 8 LOCKING BOLT'S....GET FROM SUMMIT OR JEG'S
ALL THE ENGINE TWISTING....AND HEATING AND COOLING OFF....WILL LOOSEN YOUR BOLT'S....
EVEN A PIN SIZE HOLE WILL DRIVE YOU NUT'S AND I MEAN A STRIGHT PIN...
WHEN YOU REMOVE THE OLD GASKET'S...LOOK FOR LITTLE BLAQCK STRIGHT LINE'S.......YOUR PAL MARK.....RAGENRAT638
rage'nrat638 is offline   Reply With Quote
Old 08-14-2004, 05:47 PM   #4
76bonanza
76bonanza's Avatar
Well I am sorry I started another thread but I can find no leaks bolts are tight and gaskets are new. Many people have told me that they make that ticking and poping noise in the collectors because they are thiner than manifolds. Just trying to make sure they are ok.
1968 c10
lowered 3" 4"
Old 08-14-2004, 05:53 PM   #5
Destructo
I hear no ticking with my headers on my 350, right now I have a partially back gasket which ticks sometimes under throttle, but it clears up after it gets warm. I have copper gaskets on my collectors and they work MUCH better than the paper/metal gaskets.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
