Old 08-14-2004, 04:45 PM   #1
terrym1
terrym1's Avatar
mustang II front suspension
Can you fit a mustang II front suspension in on of our trucks? Mine is a 68 half ton ,if so how much work is involved? Any comments are welcome
thanks terrym1
terrym1 is offline   Reply With Quote
Old 08-14-2004, 06:09 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, there are folks who sell Mustang II front crossmembers for these trucks.
I've built several street rods with Fatman Fabrications front MII crossmembers and have always been very happy with their products.
Old 08-14-2004, 09:36 PM   #3
terrym1
terrym1's Avatar
how
How many mod's do you have to do to these ie.widen , bolting up? any info would be helpfull.
thanks terrym1
Old 08-15-2004, 03:53 AM   #4
68LSS1
68LSS1's Avatar
Depends on the "stage" of the kit with the Fatman set up. I used the stage 3 which gives you polished, tubular A-arms and coil overs. The cross members are bolt in. The only welding necessary is to weld a gusseted (sp) spacer to the cross member for the lower A-arms. I'm not sure if this needs done on the stage 1 or 2 kits. The stage 4 kit is the airbags and I'm not sure about any welding on that one either. You get other options on things such as the rack (power/manual), brakes (stock GM or aftermarket), and 5 on 4 3/4 or 4 1/2 rotors, etc. It's good for 5" of drop and if you want more you can get dropped spindles. One thing I definately like is that all the parts used are off the shelf items. If you need a ball joint, wheel bearing, whatever, you can get it no problem. All the parts came from various cars but all are off the shelf. Ed at MOTHERTRUCKERS is a authorized dealer for Fatman Fabrications. Drop me a email if you want some pictures as I have a few of the trial fit from last year.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 08-15-2004, 01:37 PM   #5
terrym1
terrym1's Avatar
My e-mail is terrym1@tru.eastlink.ca send your pics if you like thanks for the info
terrym1
Old 08-18-2004, 09:20 PM   #6
GMCGRANDS
68lss1
I would like to see some pictures as well. gmcgrands@aol.com
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 08-19-2004, 07:52 AM   #7
Bowtie67
Bowtie67's Avatar
Here is a pick of my setup from Scott's Hot Rods (which I would nto recomend) Fatman has setups, so dosnt TCI, and a few others as well, anything from bolt in to weld in setups. Also note that the mustang rack & Pinion needs a regulator of sort to cut down the pressure of the Power Steering pump, the Thunderbird does not. The one main thing I dont like with using the Rack & Pinion setup is the steering column to R&P hookup, now some of the others may not be as bad as mine but if you look at the picture here and look at where the stearing column is to where it has to go for the steering rack. Also note that you will drop about 200lbs out of the frontend if get rid of the clunky stock setup. Also note that no one sells 6 lug rotors for these after market IFS setups so if you want all your lug patterns to be the same you will have to redrill or replace the rear axles.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
