Wanted 3:42 gears for a 1985 4x4 (rear)
I need the ring and pinion for a 12 bolt but would consider whole rear end .I live near St. Louis . Prefer some thing local but I'll consider other options. I would like to have a locker also. Email me at drka@charter.net
Jesus Rules Last edited by denny350; 08-14-2004 at 06:31 PM. Reason: fix type-o |
I have a brand new set of 3.42 gears(12 bolt) that I bought off of ebay and never used. $110 shipped to your door. I am going with a 4.11 instead so I won't need these. I take paypal too.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
Oh,you can't buy that new
![]() Join Date: Apr 2000
I have a clean used set of the factory 3.40 ratio 12 bolt gears, Since this is a ratio that I use I like having a set around, but I am buying airmales entire 10 bolt when he's ready so I'll let this set go for $40 plus ride. the splines on the yoke end of the pinion gear got slightly flattened and can either be filed or toucked with a dremmel type whizzer wheel. this makes no differnce in the strength its just that the pinion yokes won't start on until thye are fixed. It's not rocket science and if i had a loose yoke here I could fix em up. lemmeknow, DAVE
all4trux@snip.net
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
