What I drive
NOW...it's missing!
I know the obvious things to check but could the charging system cause a miss? A bad ground? I also changed negative battery cables yesterday and the smaller wire that comes off of the bigger wire and goes to the rad. support, had a crimp on connector on it, so I cut the other wire and crimped it in the other side.....could be my problem? The lights also flicker at idle corrosponding to the miss. Ran great until today!
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
