Few problems with new truck
Just bought an 89 Silverado.
The other day I had the wipers on delay when they started running non-stop no matter where the switch was turned. I couldn't even turn them off. Eventually they went back to operating normally. My left turn signal doesn't turn off automatically. My cruise does not work. Driver's side window (electric) goes down fine but on the way up it gets stuck in two spots. It "chatters" at these points but will go up if I help it along a little. It also chatters at the top like it is still attempting to go up. Any help would be appreciated!
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
1999 Chevy
The Wiper Problem Could Be The Wiper Control Module Its Located On The Fire Wall Attached To The Wiper Motor Its A Common Problem On These Trucks. To Me There Is A Easy Fix For The Trouble That Is Caused By The Mod And It Is Cheaper That Replacing It. You Need To Know How To Use A Soldering Iron. Just Solder The Connections On The Plug.
MooMoo
cruise and blinker problem sounds like your multi function switch I had to replace mine, dealership also says thats a common problem, defiately a real pain to replace, and a pricey part.
<--Thanks 86 Red Bowtie
97silv5.7-- Did you fix the muti function switch yourself? If so, do you remember where it is?
Cam
race2c@aol.com 1941 Willys Coupe--Currently being put together. Willy Works fiberglass car. 1969 Chevy K10 SWB--SOLD!!! 1989 Chevy Silverado Z71 RCSB--SOLD!!! 1993 Pontiac Grand Prix--College Commuter |
MooMoo
the multi function switch is the so called wonder stick on the side of the steering wheel that control everything blinkers cruise etc, I spaced out and didnt notice you said 89 truck I would imagine its probably a different setup than my 97, if it isnt than you would have to remove the steering wheel to get to the wiring.
Thanks guys at least I have a starting point.
I had the same problem with the wipers and replaced the wiper motor, but the cruise and the rest is the multi function switch as stated elsewhere
| Bookmarks |
