Old 08-15-2004, 05:26 PM   #1
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Question how do I get the oilpan on my 250 off? Help please...
Hey all. I'm putting a new clutch in my 67 GMC & I need to get the oilpan off so I can change the rear main seal so I dont have to change the clutch again soon. I have all the bolts out & its not hitting the crank, its hitting the oilpump. Any tips? It's almost an easy take out except for the pump problem...... Thank you sooo much for your help & advice!
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-15-2004, 05:43 PM   #2
dtlilly
dtlilly's Avatar
If I remember right, I took the motor mounts loose, then jacked up the motor so I could get the pan off.
dtlilly is offline   Reply With Quote
Old 08-15-2004, 09:53 PM   #3
passthebuck
I had my fingers crossed hoping that I didnt have to jack the motor up, but I will if I gotta - Anyone else?
passthebuck
#5642
Old 08-15-2004, 10:07 PM   #4
whitesswj
Embrace the Redneck
whitesswj's Avatar
that's how i had to do it too. jack it up
sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 08-15-2004, 10:27 PM   #5
tphsmith
still buypickupparts
tphsmith's Avatar
just put a new rear main in my 250, I used a short block of wood on the side of the block, and a floor jack, pulled one side of the motor mount and had enough lift to slide the pan out. not hard at all
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 08-15-2004, 10:39 PM   #6
dtlilly
dtlilly's Avatar
TPHSmith, I too thought it was possible taking one side loose, but didn't know which side so I took em both out. Is it the passenger side that will jack up far enough to get the pan off?
Old 08-16-2004, 07:58 PM   #7
tphsmith
tphsmith's Avatar
DT I took the left side out, passenger side bolt out of the motor mount. and I didnt have any problems sliding the pan past the oil pump. now maybe because the 250 I worked on was on my 81, but still there shouldnt be that much diffrence I would think
Old 08-16-2004, 09:54 PM   #8
dtlilly
dtlilly's Avatar
Thanks for the help
