sold
bagged 87 and older owners
ia everyone running a lower cup, i was thinking about taking mine out , but dont know if i would need to cut the lca. im trying to get a couple more incs of drop for free.
07 Rubicon, 2" lift,35's on some bling'n 20"s, warn winch. (20's for sale, 5on5) looking for 73-87 crew cab with 8' bed,2wd,PM me if you see one around |
Happy to be here
![]() Join Date: Mar 2000
How are you going to locate the bag at the bottom if you take the cup off. You can't bolt it in at the bottom. I don't see how not having the cup wi lll let you get any lower. Your LCA's will drag long before that. Here's a pic of my 82 Blazer.....
sold
well i still have stock spindles, and a tall wheel/tire combo. so i figured without the cup the truck will sit that much lower. what components do you have into that setup there?
Happy to be here
Dude get some spindles! I think your asking for trouble by taking the cups out. The bag may stay in place but I'll bet it rubs the spring pocket and pops.
What your looking at is 3" spindles, bags and the fender liners removed. At the time that pic was taken I had 245/55/18's on front.... ![]() |
sold
how are your bags mounted? mine use a upper plate that kinda "boxs" in the a-arm and a lower cup.
#6 | |
Under construction!
Ken has ART's Cool-Ride kit, as do I. BTW, I agree w/ Ken that removing the lower cup is a bad idea. Purchase a pair of 3" spindles, remove the wheel houses, and be done. ![]()
2001 Silverado bagged on 22's. *Sold* |
#7 | |
Happy to be here
Those look alot like the brackets from www.*****************, how difficult was the install and what bag are you using, any rubbing and what is a good estimation for the amount of lift you got? My truck is dropped about 5 1/2 inches in the front and dragging the ever loving christ out of the lca's and the y-pipe.....
#9 | |
Trucker.
Hey 5-8 chevy, I used to post on fullsizechevy.com under the username Dragula.....thats my burb, finally dropped..... if you still run around in the mid-cities area you should stop by the sonic on 26 in front of north hill's mall onn a tuesday night about 8:30, we have a purely truck hangout going and dont get kicked out, couple bagged and bodydropped trucks are always out and it's usually pretty cool. l8er
#11 | |
Trucker.
![]() Truck's lookin' good. |
sold
i have the stuff from suicide and it worked fine , only cutting i had to do was the bunpstop /sterring lock thing.
#13 |
www.loweredd.com
I used upper and lower cups from the next body style up from ours. 88+ trucks. It locates the bag higher in the spring pocket up top. It mounts differently on the top cup however. Depending on what size wheel/tire combo you will be runing, this will get you lower aired out then our model specific mounts, IF the compressed bag/mount combo is holding you up.
Right now, when completely airless, my arms and crossmember are at least 2" off the ground. |
