Old 08-16-2004, 09:45 AM   #1
JJGMC71
Taking coil springs out
I am currently stripping my frame down so I can take it to get blasted and painted. What is the best was to take the coil springs out? Right now I have everything elese off the truck so i am just working with a rolling chassis
JJGMC71 is offline   Reply With Quote
Old 08-16-2004, 09:57 AM   #2
sactoC10
71 DELUX
sactoC10's Avatar
front or rear ? or all ?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 08-16-2004, 10:14 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Fronts - Either unbolt the lower control arm or pop the lower ball joint.
Rears - Disconnect the trailing arms from the u-bolts. There are also retainers inside the spring top & bottom that need removed.
On both, loop a length of chain through the spring, keeps it from flying out.
Easiest way is to use your torch. They need replaced, anyhow.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-16-2004, 12:02 PM   #4
Blue68
Blue68's Avatar
On the front, if you have the engine out and the body off, the springs won't have much resistance, and thus, when you pop the ball joint or undo the control arm, there won't be enought weight to contain the spring. You'll need to rent spring compressors from your local auto parts to retain them.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 08-16-2004, 12:04 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
In the rear, there is no need to mess with the u-bolts on a coil spring truck. The spring has nothing to do with the u-bolts back there.
Old 08-16-2004, 12:11 PM   #6
JJGMC71
Thanks Blue68, that is exactly what I was thinking, I did not want to pop the lower ball joing and have a accident of some sort.
