Old 08-16-2004, 07:13 PM   #1
Guff
Guff's Avatar
Need input on a 67 SWB I'm thinking of buying
Found this one recently and it looks pretty good to me, but what do I know? It has a good running 350 with a carter carb, aluminum intake and hei ignition. looks like one front fender has some rust through, as does on floor pan. should i be worried about what might be under the shiny red paint?
Thanks,
-Guff
1969 C10 LWB, 350, 700R4, 3.73 gears
Guff is offline   Reply With Quote
Old 08-16-2004, 07:17 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Well It Needs Floor Pans, Rad. Support, And Front Fender New / Or
Repaired With Bottom Section, Look At The Cab Corners, Rockers,
And Body Support Real Good, It All Depends On Price And Your Level
Of Work You Are Willing To Take On, It Appears To Be A 67 Though,
And A Small Back Window W/ A Slider, How Much Do They Want
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-16-2004, 08:01 PM   #3
neonlarry
neonlarry's Avatar
With that bondo rust repair I would definatly take a magnet to the rest of the body to see what else might be covered up. Like LUV2 said it depends on how many $ and how good and how much sheet metal work you want to do.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-16-2004, 08:55 PM   #4
Guff
Guff's Avatar
I forgot to mention that I think I can get this truck for 2000, definately 2200 or less. So you guys are saying that is a bondo repair that has failed on the front fender? I'm not too concerned about having to do some sheet metal work, as long as the repairs are not too costly, are the floorpan repairs needed on this truck labor intensive? As long as the bondo repairs are limited to the typical rust areas, that;s fine as long as the cab is pretty solid. I want to drive the truck for a couple years before I start restoring it with my son. What do you guys think about it now knowing the price?
-Guff
Old 08-16-2004, 08:58 PM   #5
Joe67
67 is sold
That bed looks tweaked?? Check the frame close for signs of being straightened.
The rust you posted pics of is quite common. I don't understand the pocket designed into the front of the fenders - great breeding ground for rust...
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-16-2004, 08:58 PM   #6
67cst
i love summertime
67cst's Avatar
small back window slider!!! didnt know such a thing existed...i want one
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-16-2004, 09:07 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Are Those Wheels Old School Slots, What Tranny Is In It, What
Rear End, Assuming It Has Trailing Arms, A/c, Power Anything, A
Pic Of The Glovebox Sheet Would Help Determine Value Better.
Old 08-16-2004, 09:15 PM   #8
LONGHAIR
The cab/bed alignment may be the rear body mounts also....
LONGHAIR is offline   Reply With Quote
Old 08-16-2004, 09:19 PM   #9
krue
Designated A-hole!
krue's Avatar
In my part of the country that might be a little high. Of course we don't use salt on the roads down here.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-16-2004, 09:58 PM   #10
1971 Cheyenne
1971 Cheyenne's Avatar
like Trav said, there was bondo rust repair in that fender, there is most likely more. Take a magnet to it before you even think of buying it.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 08-16-2004, 11:16 PM   #11
Guff
Guff's Avatar
Thanks for all the input guys. The truck is from northern arkansas originally. I have not looked at it in person yet but am seriously thinking about making the trip. I've heard that the rust in the passenger side floorpan could have been caused by a leaky heater core, is that a possibility? Also, the rust in the rad. support and front fender is usually caused by a battery leak? Maybe it's wishful thinking but, if those are the two problems that caused the rust, it's possible there isn't much more bondo on the truck, correct?
-Guff
Old 08-17-2004, 01:44 AM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Way too much money and way too much rust! That cab will need corners, supports, floors front and rear, probably all the cab mounts, kick panels and front and rear pillars. This will be lots of work unless you have done a couple of these already and have the welder and all the sheet metal tools. Good luck!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-17-2004, 03:17 AM   #13
69 Short Fleet
Welcome to the board Guff, I would suggest bringing someone that has some experiance with bodywork with you when you go to look at it. I would DEFINITLEY do the magnet treatment (as previously mentioned) on that truck, other than replacing the hood & front quarters panel placement can get pricey if you have a professional do it. VERY nice choice in truck though. Reagards Doug
69 Short Fleet is offline   Reply With Quote
Old 08-17-2004, 07:41 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Look close in the first picture. There's nasty hidden bondo running up the front door jamb out of sight on the picture. See the scratches under the paint?
Honestly, around here, that would be a drivetrain donor. These trucks are still common enough that dealing with that quantity of rust is really only worth it for an extremely rare truck or one with high sentimental value.
Old 08-17-2004, 07:49 AM   #15
GMC AMI
GMC AMI's Avatar
Magnet ettiquette !
If you pass the magnet over the body of the truck, which is sound advice,
place a tissue on the magnet first so the owner won't try to say you scratched the finish doing so. If unable to do your own work on this body it can become quite costly when the grinding starts and reveals someone else's
butcher job. Most body guy's I know hate to repair what some one else screwed with. Good luck however you proceed. I found a truck that had 3 cab corners on the same side .
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-17-2004, 08:24 AM   #16
Guff
Guff's Avatar
Thanks for all the input guys, guess I'll let this one go. I honestly wouldn't mind having to replace the sheetmetal since there are quality repro parts available, I just don't want to have to do a ton of work to make the cab right. The only things that I need right now are a straight frame and a decent cab on a truck that runs and drives good (preferably 67 swb). I will not be restoring the truck for another 2 or 3 years. So for $2k, I guess I should look elsewhere. These trucks are nowhere to be found in my area, and what few you can find are usually completely rusted out and barely running if at all. I've been looking for over a year, since my 2002 Sierra was stolen. If any of you know of a truck that fits the above description for $2k or less within 250 miles of south-central illinois, let me know! From Kansas City to Inidanapolis, Peoria IL to Paducah KY....still looking.
-Guff
Old 08-17-2004, 08:41 AM   #17
64fleetside
Is that red truck in Oklahoma? Tom Myers? Brian
64fleetside is offline   Reply With Quote
Old 08-17-2004, 08:48 AM   #18
raggedjim
raggedjim's Avatar
Guff, you are in the right place to find a decent truck, or at least get good leads. Hang in there and don't get in a hurry, I've learned the hard way, I'd take a rust free body with a non running straight 6 over a rusted shell with perfect running gear any day.
Good luck, Roger
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 08-17-2004, 09:46 AM   #19
Mudder
Mudder's Avatar
I sorta thought the same thing but lots more stuff sitting around than the last time I was there.
Mudder is offline   Reply With Quote
Old 08-17-2004, 10:09 AM   #20
Guff
Guff's Avatar
Yes, this is Tom Myers' truck in Oklahoma. Have either of you seen the truck in person, or want to take a look at it for me next time you're in the area?
-Guff
Old 08-17-2004, 10:14 AM   #21
64fleetside
I just recognized the place, lots of good stuff there. I bought a NOS rh fender from him. There are some trucks around with less rust for similar money. Fenders, core suppoprt etc not realy an issue, all that stuff unbolts easily, look mostly for good cab metal. Brian
Old 08-17-2004, 10:24 AM   #22
Mudder
Mudder's Avatar
I've bought from Tom. I'm about 5 hours away so I cant really go look for ya. I bought lots of stuff from him at one time. You do need to check it all out. I would be leary of that truck.....Just looks like it will be needing lots of metal work in 2 years. They can pretty much fall apart in 2 years driving them. I know!
Keep watching the board here there are some nice trucks that come up for sale here.
Old 08-17-2004, 10:43 AM   #23
Guff
Guff's Avatar
Thanks anyway Mudder, I guess I'm about as far away from the truck as you are, I'm 60 miles east of St. Louis On I70. I've been watching the board for over a year, I'll keep watching though.
One more question...Are you saying that if I buy a truck that needs some sheetmetal patched on the cab, I need to do it right away an not wait a couple years because it will rust away to nothing?
-Guff
Old 08-17-2004, 11:56 AM   #24
Mudder
Mudder's Avatar
I know when I bought my truck it had a lot of bondo in it. I paid 1800. In about 3 years in was getting pretty bad. It went down hill pretty fast. Rust will only grow......I know of a longbed (68) I think near here that is for sale. Has no rust, 37,000 actual miles, 6cyl. Guy bought it then got sick. he paid 6500 for it. It had no rust.
