Old 08-16-2004, 10:54 PM   #1
69 longy
69 longy
need help on my longy project it is 3/4 ton need to change to 1/2 ton 5 lug so what years can i swap it from and what do i need actactly to make this right and does any one have 1/2 ton used and or will trade for my 3/4 ton and also i need the front and rear
69 longy is offline   Reply With Quote
Old 08-17-2004, 12:30 AM   #2
crazy longhorn
Fabricate till you "puke"
you can use a 73 up 1/2 ton for donor parts....swap the complete front crossmember in, & use the rear diff with a swap kit Ill try to dig up a link on the kit.... http://www.classicperform.com/produc...ersion-Kit.htm the kit will require some welding , but using the later parts is a nice option(more availability). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-17-2004, 01:56 PM   #3
69 longy
thanks alot
Old 08-17-2004, 05:11 PM   #4
69 longy
any one have other answers
