Senior Moment
![]() Join Date: Mar 2002
Where to get Oil Pressure from on a BB
My small block oil pressure line hooks up just behind the distributor. I'm building a Big Block and noticed it doesn’t have the same outlet.
Where do hook up for Oil pressure (gauge) on a Big Block. Pictures would be nice Thanks ![]() ![]() ![]()
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Resident Curmudgeon
![]() Join Date: Dec 1999
LH side of block down by bosses for clutch linkage (assuming Gen IV BB here). In other words, near oil filter.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Lovin' Life in Miss.!
Are there any more oil ports on small block chevys? I'd like to run a light and a gauge and dont want to tee off the same port unless I have to.
Rich
The truck... you hear that? No really, you did hear that?!!! |
Some small blocks have an oil plug in the front of the block, on the passngers side I believe. It is a 1/8" npt plug so it is the same size as the one in the rear behind the distributor.
Jim |
Senior Moment
Thanks for taking my post.
Anybody have photos of where the port is on a big block. I'd like to see the line hooked up Thanks
My apologies. Thought since we were on a similar subject...
Rich
#7 | |
my big block 402 is on the drivers side down on the bottom above the oil pan. It is easier to get to from underneath than it is on top. I can get a picture if you would like.
thanks Ron
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
Senior Moment
A picture is worth a thousand words. Could you Please take one, I would appreciate it
I will take one in the morning when it is light. Glad to help.
Ron
Watch out for your cornhole !
![]() Join Date: Jun 2003
Better picture. You can see where the line screws into right above the oil filter. It's the same 1/8 npt as the small block you took out had.
#13 |
Nice garage! Cute helper!
#14 |
Here is a closeup shot. We had to use reducing bushings to get down to the 1/8 pipe fitting.
Jim |
#15 |
Senior Moment
Thanks Guys. I'm all set
