Truck addict
body mounts
I have been looking around for a complete set of cab/rad/bed mounts. Is there much difference between Polyurethane, and just normal rubber. I want original oem style, and the sets I have looked at seem to vary in their design. Does anyone know what the correct style should be? And has anyone had any luck with certain sets. Thanks
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
Senior Moment
![]() Join Date: Mar 2002
I've replace body mounts on 2 trucks and went with the original rubber type. Most of the venders here have them. The Poly ones I'm told can make noise.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
67-72 Addict!
I have also heard this plus they give a stiffer ride. I would go with stock rubber type. They should hold up for another 30 years!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You want good ones?
Go to your local GM dealer: Core support bushings upper 3951798 Core support bushings lower 3953135 Cab mount rear complete 3957829 Cab mount Front upper 6262169 Cab mount Front lower 6262168
![]() Join Date: Jan 2001
Are those GM #'s for the 1/2 ton or 3/4 ton pieces?
sorry, they're half ton numbers. Disregard my post. You may now return to your regular internet viewing.
#7 | |
good to know for the 1/2 ton crowd though! thanks ![]() |
67 is sold
Thanks for the PNs TX!
I just pulled the bolts from my 67 last night. Of course the Left Front nut spun with the bolt.... |
