Old 08-17-2004, 07:39 PM   #1
me3
hart
Will a disc brake caliper off a 74 caprise work
I have a bad one it was all originally off a 79 1/2. please help. if nothing can the piston work. Im on a very low budget and if the old beaters will work thats great.
me3 is offline   Reply With Quote
Old 08-17-2004, 10:00 PM   #2
silvertonguedevil
silvertonguedevil's Avatar
I guess I'm not following what you are asking. Will the brake caliper work on what? And you have one off of a 79 1/2 what?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 08-17-2004, 10:24 PM   #3
me3
hart
I have a junked 74 caprise for parts. I have a 68 stepside I am putting a 79 disc brakes on (just spindles and stuff not the whole crossmember. but one brake caliper is shot I cant even push the piston out with 120 psi of air pressure. my guess is that they will swap but I think someone beat on the caprise. basically willl the piston swap if I can pop them both out.
Old 08-17-2004, 10:43 PM   #4
silvertonguedevil
By the 79 disc brakes, do you mean pickup or Caprice?
-Greg
1974 C20 Cheyenne
Old 08-17-2004, 11:02 PM   #5
me3
hart
truck
Old 08-18-2004, 07:55 AM   #6
JJR
JJR's Avatar
I looked on Hollander and it looks like the 74 Caprice caliper is different than the 79 C-10. The Caprice caliper would work on a 71-78 C-10 but not 79-up. I looked on Advance Auto Parts website and it shows the same part numbers for the piston's (I had to campare a 75 and 79 C-10 because they did not show anything for a 74 Caprice) so you should be able to swap. Also, the rotors are the same on the Caprice and the 79 C-10 so you could use the thickest set. I know how limited budgets can be, but you can get a re-man caliper for under $15 at the parts stores for the 79 C-10. The price of the piston by itself is $17 (go figure).
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 08-18-2004, 05:39 PM   #7
me3
hart
thanks a lot most people would tell you to buy new Ill have to try to pop the pistons tonight.
