Chevelle coils??
I remember reading on here in a bunch of different posts that using pre72 chevelle springs in the rear of our trucks will lower it, but I can't remember exactly how much.
The reason I want to know is I am planning on going through the AC Delco spring book to try to match something up to the factory springs that will drop it but not change load rates too much (which I think the chevelle spring will probably do). I am thinking that if I find some that will work I should be able to do this for about 1/3 of what actual drop springs will cost.
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Look at Early Classic Enterprises. Springs made for our trucks,... to lower the amount you want,...GOOD STUFF!
hart
If You have MONEY most of us that ask to use the chevelle spring are looking for a cheaper route.
Saving 1 truck at a time!
"A' body springs lower it but not nearly enough! They are like $10 at the swap meets but I think they only lower it about 2-3 inches.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
2-3" Is exactly what I am after. I am going to try for a 2" front (coil cut) and 3" rear.
Can anybody verify the 2-3" thing with chevelle coils?
when I bought my truck, i was told that it had cut 72 coils in the front and chevelle springs in the rear........i'd say it was about a 5/6 drop.... So I'd say the chevelle rear coils are about a 6" drop if I was correctly informed.
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had" |
