Almost done!
F/S 1987 1 Ton Frt End DFW
A co-worker has a 1987 chevy 1 ton front end he would like to get out of the yard. He had the rolling chassis but used the rear end then torched the frame just behind the front cross member. He left the wheels on to help move it around.
It has frt disc, calipers, rotors, steering gear, and shaft, the whole works. The only front end part missing is the sway bar. (Yep, its mine). He thinks it even has the master cyl & booster. Sorry no pic's yet. The only catch is, IT HAS TO BE PICKED UP. NO DELIVERIES. You could pick it up for less than $50.00. Looks like a bargin to me...
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
2WD front end right?
Almost done!
yep, It is a 2WD, dually
