Old 08-17-2004, 11:03 PM   #1
charlieo
blazer frame question
Does anybody know what pickup bodies will fit on a 74 blazer frame ? I'd like to build something different.
charlieo is offline   Reply With Quote
Old 08-17-2004, 11:42 PM   #2
Mudder
Mudder's Avatar
Blazer frames are the shortest made that I know of. They are too short for shortbeds. You would have to lengthen it to do it right.
Mudder is offline   Reply With Quote
Old 08-18-2004, 10:22 AM   #3
Truckstuff
Truckstuff's Avatar
The 73 - 86 Cab and Front End will fit. You will have to shorten a short Box in the front. Or build a deck. I believe a Blazer frame has a 105 Inch wheel base and a short box is 115. It can be done if you have the time.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 08-18-2004, 10:35 AM   #4
Truckstuff
Truckstuff's Avatar
Here are a couple of up to date pics of mine. 1981 Body with a 1979 Blazer Frame. The 79 Frame has no rear cab cross member, Had to build my own. The 74 Frame should have one.
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 08-18-2004, 10:51 AM   #5
Mudder
Mudder's Avatar
Lookin good Truckstuff.......
Old 08-18-2004, 02:55 PM   #6
charlieo
Hey guys thanx for the replys please keepum coming ! Truckstuff did you shorten the bed & if so how did u do it ?
Old 08-19-2004, 08:16 PM   #7
Truckstuff
Truckstuff's Avatar
Thanks Mudder67, Sweet 67
charlieo, I shorten the box in the front. Took aprox 11 Inches out. Cut it with a zip disk, and mig welded back together.
You can check out more pics at http://community.webshots.com/user/truckstuff101
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 08-19-2004, 08:25 PM   #8
jollyroger
I mounted a 58 cab on my 74 chassis. I used the mounting brackets off the 58 frame. The step side works fine. I moved the fenders forward and shortened the steps. The frames ends just under the rear of the bed. I will build a bumper and receiver unit to fit. I used mounting blocks to raise the cab to the right height to clear the gearbox and transfer case.
jollyroger is offline   Reply With Quote
