Old 08-17-2004, 11:53 PM   #1
stretch
Inline 6 question
So, I picked up a 250 inline 6 from a buddy for nothing (along with a T-10 gearbox, bellhousing, clutchpack, starter, HEI dist, pulleys, carb, etc). I haven't fired it up, but it was supposedly a performance build. The weird thing is, the casting numbers say the block is a 250, but the heads are for a 230. Is this common with these inlines? I know next to nothing about these particular engines or tricks that are done to them...
'71 Custom 10
350/TH350/3.73
Holley 650 Dbl. Pump, Headers, HEI
'76 K10
350/TH350/205/12-bolt(R)/Dana44(F)
Primer Gray!
'01 Grand Prix GTP - my 260 HP gas sipper!
Victory Red
stretch is offline   Reply With Quote
Old 08-17-2004, 11:56 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Very common. The head interchanges between 230, 250 ,and 292 engines.
The 292 is pretty different below the head though.
Old 08-17-2004, 11:57 PM   #3
rage'nrat638
rage'nrat638's Avatar
Thumbs up
DON'T KNOW ABOUT THE HEAD THING......
BUTT....THE 6 CLY....H.E.I. IS GOLD.......DOHOOOO....
rage'nrat638 is offline   Reply With Quote
Old 08-18-2004, 07:27 AM   #4
JJR
JJR's Avatar
I am not positive, but I believe the 230 head has a smaller combustion chamber than the 250/292 head so it will give you a higher compression ratio. It is an easy way to gain a few horsepower.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 08-19-2004, 01:24 AM   #5
jimfulco
It's the 194 head that has the smaller chamber. The only difference between the 230 & 250 is the crank & pistons. Block & heads are the same.
jimfulco is offline   Reply With Quote
