Old 08-18-2004, 02:15 AM   #1
skokie
skokie's Avatar
Power Steering Belt Issues
Ok Here it is. I cant get that power steering belt on to save my life. My setup is a 68 1/2 just converted to a short waterpump. Is there a place in the bracket to adjust? The belt part # I have is goodyear 15356. Is this correct?
skokie is offline   Reply With Quote
Old 08-18-2004, 02:52 AM   #2
motoretro
I'm not sure what your working with here although it sounds like you can't get enough movement in the PS pump bracket to get the belt on. My 72 was a pain too although by working underneath, you can spot the travel slots easier and by using 2 wrenches, you can slowly back off the bolts to allow the pump to swing inward in order to achieve enough room for belt to wiggle on. Not the best set up, especially with the PS hoses in your way. "Alan Grove" makes a sweet set up that adjusts very easily and it's steel like the oem stuff so looks stock. Hope it helps,
motoretro
1972 Chevrolet Custom 10 Lwb
www.esivart.com/ebay/truck.gif
motoretro is offline   Reply With Quote
Old 08-18-2004, 11:38 AM   #3
skokie
skokie's Avatar
Im working with the stock power steering pump and brackets for the 68 1/2 ton with a small block. WHen you say back off the bolts which bolts are you referring to? THe ones that go to the block and the motor mount or the brackets on the pump itself?
Old 08-18-2004, 03:04 PM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
there 2 bolts that keep the pump in place ...upper and lower ...loosin them up and push the pump in towards the passenger side ... i had to remove my ps belt to get my new alternator belt on ... should have done the ps belt while i was at it .. oh well ....ps is a privelge not a nessesity like the alternator
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-18-2004, 11:08 PM   #5
skokie
skokie's Avatar
That was it. I got the belt on there now. Power steering is working fine now.
