Old 08-18-2004, 11:22 AM   #1
Edmond
Edmond's Avatar
Location for Oil Temp-sender on small block?
Maybe this is a dumb question, but what is the best location for the Oil Temp-sender on a Chevy small block?
In the oil pan, where the drain plug is?
Thanks for any advice.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 08-18-2004, 02:30 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I think there is a tap where the oil filter screws in.
You could adapt a "T" fitting to where the factory oil pressure line is on the top,rear of the block.
I personnaly wouldn't put it where the oil pan drain plug is.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-18-2004, 02:42 PM   #3
ratrod67
ratrod67's Avatar
There's a spot at the rear of the intake manifold next to the distributor. That's what the factory used.
ratrod67 is offline   Reply With Quote
Old 08-18-2004, 02:54 PM   #4
Edmond
Edmond's Avatar
Yeah, but isn't that for the Oil pressure? Or am I mistaken?
Will a 'T' fitting give a good reading of the temp?
The spot near the oil filter, is that on the side of the block?
I can see a plug, or a bolt to be more precise.
Is that what you mean?
Thanks.
Cya,
Edmond
The Netherlands
Old 08-18-2004, 03:10 PM   #5
ratrod67
ratrod67's Avatar
Your correct. I read it too fast. Sorry.
Old 08-18-2004, 04:45 PM   #6
Chevy67Tk
Chevy67Tk's Avatar
The T in the oil pressure line will not work you have to have oil running over the sensor to get a reading. In my 81 I put the sensor in a T of the return line from the oil cooler.
I doubt the threads will be the same on the oil drain plug and the sensor, I drilled and welded in a bung on the pulling tractor oil pan and that worked fairly well.
Chevy67Tk is offline   Reply With Quote
Old 08-18-2004, 10:25 PM   #7
pritch
pritch's Avatar
I believe that plug near the oil filter is the same threads as the drain plug. Last time I had a block done, it came back from the shop without that plug, and no one noticed until it fired up. Then we noticed! We had a heck of a time finding a plug, tried every thing with threads on it we had and the only thing that would fit was drain plug, but that didn't stop the leak, it's got to be an allen head or pipe plug. I think if you had a skinny enough sensor, it would work there.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-19-2004, 03:23 PM   #8
68 50th
68 50th's Avatar
Hello Edmond,
I donīt know if there is any different places to put the sender unit.
What I know about this thing is that there was an aftermarket oil temperature gauge mounted in the Camaro I bought in Germany and the sender unit was built in to the drain plug.
I did replace the instrument panel to an unmolested original as well as the the drain plug.
I think I have the sender/drainplug somewere, you can have the sender for free if you want to go with that solution, just let me know.
I send it to you in an envelope, if I can find it of course.
Mats..
68 50th is offline   Reply With Quote
Old 08-19-2004, 03:52 PM   #9
Edmond
Edmond's Avatar
Mats, that would be great! Yes I would like to take you up on that offer.
I hope you do find it
Let me know if you do, okay?
Cheers Mate!!
Cya,
Edmond
The Netherlands
Old 08-19-2004, 05:00 PM   #10
68 50th
68 50th's Avatar
Sure, I will go looking for it tomorrow or during the weekend anyway.
Cya Mats..
