08-18-2004, 11:38 AM | #1 |
well, the purchase has been made...now need some advice
Got a tuned port setup from a 89 Iroc, complete from oil pan to intake with all accessories and wiring harness and computer . This is going in my '71 stepside. My question is, what do I need to do about my fuel tank, fuel pump and fuel lines. What vehicle should I get these out of or is it better to get something fabricated?
'71 Chevy stepside '50 Chevy 5 window '82 K5 Blazer '90 Mustang-stroked and sprayed '95 Nissan 300 ZX '04 Jeep Grand Cherokee |
08-18-2004, 12:43 PM | #2 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Member BobbyK has TPI I believe on his Blazer. If he sees this post he'll prolly answer any q's ya got...
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
08-18-2004, 01:23 PM | #3 |
I am putting my TPI on right now.
I went with a FuelCellGuy tank. I am running my fuel lines tonight. I have half of my manifold on, and all of my wiring done so I am getting close You could go with a blazer tank and do an inline fuel pump. I have an in-tank pump, and you can always go that route too. Are you putting a Vehicle Speed Sensor in? Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-18-2004, 02:24 PM | #4 |
I have located a 700r4 so it looks like I will be able to use the speed sensor.
Does the fuel cell guy have a website? TIA, Ben
08-18-2004, 02:47 PM | #5 |
There's a 72 running around here that has the same swap. He's using the stock in cab tank with an electric pump. If you do the same you need to get the special fuel injected gas line. It's reinforced for the higher pressure of a late model system. You could also use braided hose. Earls sells a fitting to connect the metal line from the tank to the braided hose. Be sure to install a good filter also.
08-18-2004, 03:00 PM | #6 |
A-Adam A-Adam
70 3/4 ton GMC Camper Special |
08-18-2004, 04:00 PM | #7 |
Thanks for the link to FCG
08-20-2004, 09:43 AM | #8 |
Blazer tank form a FI blazer made 87-91 or a Sub made same years with 30 gallon or less tank.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-20-2004, 10:52 AM | #9 |
Professional Grade
Check out this website -- It has absolutely everything you need to know about TPI:
www.chevythunder.com
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
08-20-2004, 02:12 PM | #10 |
Use the alternator from the donar and make sure your wiring is up to snuff. Computers are fairly finicky about getting enough voltage.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
08-20-2004, 03:13 PM | #11 |
Check out this post on next page:
http://67-72chevytrucks.com/vboard/s...d.php3?t=78744
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
