Hi all I was changing my oil today and went ahead and attemped to check all the other fluids, including differentials and transmission. The reason I am asking this is because I usually take my truck to a full service lube that does it all. Anyways where is the transmission fluid check/filler at? I have the original 3 on the column and I believe muncie three speed. Where can I check for fluid at and fill if needed.
thanks ![]()
Man I need another 67-72!!! ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Look on the side of the tranny case for a plug (1/3 to 1/2 way up from bottom of case) - remove plug, fluid should be at bottom of theaded hole (on level surface) - fill through same hole if necessary.
thanks will do that tomorrow
