Timing light help / advice
What is the best "bang for the buck" when it comes to a good timing light.
I should keep it under $100 or so. It would be great if you could recomend the brand model etc. Any suggestions? Thanks! Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
faster, faster, faster
Anyt advance timing light is worth the money.
I'm going to Law School, wanna debate? It's good practice. |
Left Foot Functioning
I've had my Craftsman (one of these ) for over 20 years. $50 new from Sears.
Good, bright strobe, clip-on inductive pickup, long heavy leads. Wires unplug for storage. SSOW... ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
Not trying to steal the thread here but isnt there one that has a readout on it that tells you what the timing is set to or something like that?
Good question Skokie!
It raises a good question . . . . are there some lights that have capabilities I should consider? Darren
Timing lights are all the same, they have an electrical power source (some are self contained battery powered, others use the car battery)they fire whenever the plug gets current from the distributor. Get one with an induction pick-up (clamps on the plug wire) and a bright light. The only other option is an advance knob on the back of the light that lets you "dial in" the amount of advance you want at a given rpm , it actually "fires" at the amount of advance you select. This can also be accomplished by using a timing tape on the harmonic balancer, just another way of going about it. Hope this helps. Go with a brand name you have confidance in and you won't be sorry. Good luck and keep on truckin'...................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake 600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have a Snap-On that has worked great for me since I began as a mechanic. I wouldn't have any other brand now. You'll pay dearly for the Snap-On label though.
67-72 Addict!
The Snap-On model is awesome but like Tx Firefighter said pricey- around $400-$500. Try harborfreight or somewhere like that and see what they might have. I need one myself!.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() Join Date: Dec 2002
Harbor Freight has a Timing Light -- Dial up to 60 degrees, inductive pickup, etc....seems to be worth looking into for the price of $29.99....( Part # 40963-OBNA)
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
blood type; Retumbo
I bought my Ferret Instruments light from the local Car Quest about 4 years ago for $175ish. model no. 84. it has tach & advance up to 90*. nice narrow nose for fitting in tight spots & removeable inductive lead & a storage case. Matco tools sells them also if you have extra money to spend.
I know this may be above your intended price range but feel it is well worth it. how many do you plan on buying in your lifetime?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Sears Has 2or3 models,a cheapy made of plastic and 2 are chrome plated metal.One has dial advance but otherwise they are the same.Craftsman brand,good quality mine w/o advance dial was about $45.
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
