08-19-2004, 01:36 AM | #1 |
Stock Wire looms
Where would you bolt up the stock wire looms ( for the back of the block )for a 68 1/2 ton?
Thanks |
08-19-2004, 05:23 AM | #2 | |
for the wire looms. You might have to be happy using the other 4, top ones intake bolts, two small front that mount under heat shield mount bolts. Mike
1968 Chevy 4x4 307 4 speed |
08-19-2004, 02:38 PM | #3 |
Well that just figures Mike what heat shield are you referring to?
Thanks Brad |
08-19-2004, 03:24 PM | #4 |
note to self......take pics for Brad tonight!! I think my memory is going......
08-19-2004, 03:35 PM | #5 |
HAHAH its cool Dean. I have a 2 yr old sone and a 6 month old girl and my memory left a long time ago Definately get some of the area where the rear looms bolt into the block.
Thanks |
08-19-2004, 07:26 PM | #6 |
More loom shots!
Hey Brad, here are your PICS, Mike
The tall shiny bolt is where the rear small loom mount on a 68. I do not know if your block has this hole from the factory or not, only your shadow knows for sure!
1968 Chevy 4x4 307 4 speed Last edited by GMC AMI; 08-19-2004 at 07:30 PM. |
08-20-2004, 10:59 PM | #7 |
Ok I found where they bolt up. The bolt hoes were covered in dirt thats why I couldnt see them or feel them. Do the open ends face the firewall or vice versa?
Thanks |
08-20-2004, 11:34 PM | #8 |
Ok forget that last post I found a pic in the assembly manual. Openings face the firewall.
