Old 08-19-2004, 09:45 AM   #1
1969K10
1969K10's Avatar
closed knuckle D44 front axle
I'm needing to replace the end seals on my front axle. I'm looking for info on this axle. I would like to come across an exploded diagram, or anything else that would help me out, rebuild instructions, etc. Below I've got pictures of the axle end seals I have bought. Does anyone know if these are the correct seals. If not, do you have a P/N that I can use to get the correct seals?
1969K10 is offline   Reply With Quote
Old 08-19-2004, 09:58 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That looks like the seal for the open-knuckle axle. Mounts near the center section and the gears have to be removed to get to it. Is yours leaking at the big ball?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-19-2004, 11:11 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I found out the hard way (after trying to force the seal into the end of the axel) that the seals are inboard. My '69 has an open knuckel disk setup on it and the seals looked just like that. I don't know if they are different for the open knuckel and closed knuckel.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-19-2004, 11:32 AM   #4
1969K10
1969K10's Avatar
JIMs70GMC - I'm leaking out the ends of the axles, and out of the big ball on both ends. The ends of the axles are only bad if I've been in deep water, until I change out the fluid. The other place I know I'm leaking out of is on the passenger side either out of the ball, or the cap with (4) screws on the bottom of the ball. Here's a picture of what it looks like right now.
Old 08-19-2004, 12:52 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Get yourself a copy of Moses Ludel's Chevy/GMC light truck owner's bible. In this book(Chapter 10) he details replacing those seals, w/ pictures!
Old 08-19-2004, 02:21 PM   #6
1969K10
1969K10's Avatar
Got one on order, should be here next week!!! - thanks for the help.
