Old 08-19-2004, 09:38 PM   #1
raphyel
How do I put a pontiac BB into a 63 chevy c10
I have a 63 shortbed fleetside that I am restoring. I am trying to make a pontiac fit into it (1970 gto motor). I am trying to get some help on figuring how someone may have done it. I hope someone may have some info that will help me get the thing mounted so I can put the cab on and the front end back together. Any help will be appreciated.
Raphyel
raphyel is offline   Reply With Quote
Old 08-20-2004, 06:49 PM   #2
Lgriffin
I don't know how much help this is, but I had a 63 C20 with an Olds 350 in it, and it was a bolt in. There were no adapters, welds of any sort.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
Lgriffin is offline   Reply With Quote
Old 08-23-2004, 12:52 AM   #3
krazy_texan
krazy_texan's Avatar
i am not sure but i have a friend that has a 66 with a buick 455 in it, i will ask him how he did his.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-04-2004, 09:35 AM   #4
raphyel
I Did It
Someone had told me to try thr 67 - 72 big block chevy brackets to make the pontiac big block fit. I went through two sets of mounts before I got it to fit, But the flat brackets when coupled with a 1970s trans am motor mounts was a perfect fit. I tested the angle of the drive shaft going into the rear end and it could not have been a straighter line. I appreciate all of the help you guys have given me. Maybe I will have it done by this time next year. I am doing a full ground up restoration. Well anyways Thanks so much.
Old 10-04-2004, 03:26 PM   #5
Piper71c10
Unending Project
Piper71c10's Avatar
Got Pics?
That sounds like a good tech write up.
Piper
Piper71c10 is offline   Reply With Quote
Old 10-06-2004, 10:11 AM   #6
raphyel
Regarding pics
I have pics of the mounts as they were installed. My block still has to be bored and put back together, but I wanted to get everything lined up so that I could tie the cross member in and put the cab back on the frame.
Old 10-06-2004, 10:13 AM   #7
raphyel
partial pic of the setup
Here is a pic of how the chevy big block towers fit. The pontiac motor mounts look very similar to the chevy big block motor mounts.
Old 10-08-2004, 09:49 PM   #8
T HAUS
Good topic
As soon as I get my daily driver going again, I'm going to put a 400 Pontiac in my 72 Blazer.
Gotta love them Pontiac motors. Gobs of torque and beefy bottoms on them
1966 Chevy C-10
1970 Chevy K-5 Blazer 4x4
1972 Chevy K-5 Blazer 4x4
2003 2500HD GMC Duramax/Allison 4x4 Full 4 Door
T HAUS is offline   Reply With Quote
Old 10-10-2004, 11:01 AM   #9
raphyel
Pontiac in blazer
How are you planning to install the pontiac? Have you found a different method to make it fit? I am just curious, I am really into pontiacs above all other engines.
