Old 08-19-2004, 11:00 PM   #1
71swb4x4
71swb4x4's Avatar
Clean out your PM's
I just noticed that our PM storage has been cut in half. I was way over so I couldn't send any out until I cleared mine down.
I am sure this has to do with the server problems, and I have no problem with it at all, just thought I would give you all a heads up in case you have the same problem.
I am going to clean mine way down to try to help out with the server.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-19-2004, 11:01 PM   #2
9footfan
get up! stand up!
9footfan's Avatar
just cleaned mine up!
9FT STEPSIDE CLUB
40 1-1/2 ton stake
67 c30 disassembled & for sale
70 gmc 3500 canadian 9 foot "fenderside" pickup
06 silverado
71 vet enjoyed by my retired father
wtb-67 chevy 1 ton 9ft stepside-in perfect condition
9footfan is offline   Reply With Quote
Old 08-20-2004, 09:38 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Good idea.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-20-2004, 09:48 AM   #4
ronh72c10
Cleaned mine out too, don't forget you can export them to a text file (or xml or csv) so you don't have to lose them. Store them local so you don't put the load on the server.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 08-20-2004, 11:32 AM   #5
Timmerduder
Timmerduder's Avatar
cleaned mine
thanks for all your hard work here
Tim in Oregon
http://timmerduder.com/72chevy.htm
Timmerduder is offline   Reply With Quote
Old 08-20-2004, 12:11 PM   #6
UP GRADE
one set closer
UP GRADE's Avatar
just clean mine
UP GRADE is offline   Reply With Quote
Old 08-20-2004, 12:15 PM   #7
sactoC10
71 DELUX
sactoC10's Avatar
Deleted! Most from the sent items section, where I ferquently forget to go delete them. Good input.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 08-20-2004, 12:38 PM   #8
skokie
skokie's Avatar
Mines done.
skokie is offline   Reply With Quote
Old 08-20-2004, 01:29 PM   #9
72BLAZERDUDE
72BLAZERDUDE's Avatar
Just did mine. Always forgetting those sent ones.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-21-2004, 02:22 AM   #10
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Whoops. I just deleted a few phone #'s!
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 08-21-2004, 08:01 AM   #11
MACKL
Almost done!
MACKL's Avatar
Cleaned mine up,
Clean as a baby's behind, wait, that not very clean. How about,
Clean as my bank account after buying a 1970 chevy truck. Now that is clean...
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 08-21-2004, 08:22 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
cleaned mine yesterday.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-21-2004, 08:30 AM   #13
MACKL
Almost done!
MACKL's Avatar
There are some other ways to help also. Turn off the auto suscribe feature, delete all old suscription, delete any old attachments.
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Old 08-21-2004, 09:33 AM   #14
crazy longhorn
Fabricate till you "puke"
Done
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-21-2004, 07:16 PM   #15
zooza
clean 'em out,,, its easy!
zooza is offline   Reply With Quote
