Old 08-20-2004, 09:15 AM   #1
Bram
Broke
Bram's Avatar
Question Vintage Air Question ?
Does anyone have any pictures of the engine compartment where the new Vintage Air lines run through? I want to see how much space is there compared to the old.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 08-20-2004, 02:13 PM   #2
Blue68
Blue68's Avatar
Are you talking about through the firewall or through the core support?
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 08-20-2004, 03:53 PM   #3
Bram
Broke
Bram's Avatar
The firewall, sorry I should have clarified that.
Old 08-20-2004, 04:08 PM   #4
Blue68
Blue68's Avatar
if you take a look at the firewall on the left, you'll see some aluminized insulation material sticking out. That's the hole the vintage air unit uses. The unit uses a plastic shield that mounts over both holes. The hoses go through a raised box where the hole in the insulation is that's about 5x5 and protrudes maybe three inches (these measurements are all memory). I don't have any pics of it before.
Old 08-20-2004, 04:18 PM   #5
Bram
Broke
Bram's Avatar
Thank you, thats what I thought. It really free's up alot of space.
Old 08-20-2004, 04:22 PM   #6
Blue68
Blue68's Avatar
Yes, it does. I've had a plate welded over the hole on the right and the round hole where the squirrel cage was. I'm not a clean freak on the firewall, but those are some big holes where noise and heat can squeeze through.
Old 08-20-2004, 04:37 PM   #7
68 50th
68 50th's Avatar
Here is a pic.
Not my truck.
http://www.select-motors.net/classif...ndex=5&go=next
68 50th is offline   Reply With Quote
Old 08-20-2004, 04:45 PM   #8
Bram
Broke
Bram's Avatar
Thats a good picture. Now we have a before and after.
Old 08-20-2004, 05:20 PM   #9
jorgensensc
jorgensensc's Avatar
Look on page 2 for a pic of my Vintage Air installed. It was really easy and cleared alot of room up in the engine bay. It really doesn't look any bigger inside the truck either.
Link to pic of V.A. Installed
Hope this helps!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
