Old 08-20-2004, 02:53 PM   #1
Half-Ton
Engine want run
I have a 1982 1/2 ton pickup with a 350 engine, I just replace the carburator taking off a Holly, replacing it with a Carter. My problem is the only way I can get the engine started is to prime the carburator. I've changed the fuel filter, I've checked to make sure the fuel was pumping up to the carburator & it is, but it want stay running. What am I doing wrong?
Half-Ton is offline   Reply With Quote
Old 08-21-2004, 12:01 AM   #2
Russell
Professional Grade
Russell's Avatar
Umm, dumb question, but is your fuel filter in the right way? If you've got it in backwards, then it won't get any fuel...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
