Old 08-20-2004, 03:13 PM   #1
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Thumbs up Anyone Interested; Body Drop Cab
I have been working on this cab for months and am kinda burned out, I just want a rust free cab. It is a 69 cab with a modified 4" body drop. Modified meaning, the rear frame mounts do not move, but he front on are lowered on the frame 1 1/2". Meaning under the seat the floor is raised 4", but in the foot area, it is only raised 2 1/2". I have replaced all four cab mounts, left and right floorboard, passenger side cab corner, rocker, and dog pillar. Also because of the body drop, have a custom inner rocker. I have shaved the heater box and fixed some rust on the firewall. Shaved the drip rails up to the roofline. I just replaced the whole back panel because the original was pretty beat up. I also have the cab corner, rocker, inner rocker, and dog pillar for the drivers side that still need to be installed. There is also rust that need to removed from the roofline (above the windshield), rear corners of the cab floor, and also the footwell to windshield behind the dash needs to be replaced. I have sections from another cab included to use as replacement panels. I have done alot of work to this cab, but just want to move on. I will keep the vin tag, so don't worry if you have a cab with out a title. Pictures are worth a thousand words, so hope fully these speak for themselves. My computer is broke, but I will try and check my email and pm's as often as possible. It would be easier on me and hopefully you if you just called me at 314-226-6420. I live in St. Louis Misouri. My email is JoeyDi84@msn.com. Thanks
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 08-20-2004, 03:17 PM   #2
Joey-D
Joey-D's Avatar
More pics
Old 08-20-2004, 04:28 PM   #3
Joey-D
Joey-D's Avatar
ttt
Old 08-21-2004, 12:45 PM   #4
dropdprpls10
dropdprpls10's Avatar
how much .. i might or my buddy might be intersted??
dropdprpls10 is offline   Reply With Quote
Old 08-21-2004, 10:39 PM   #5
Joey-D
Joey-D's Avatar
If you pick up this cab and bring it too me straight trade! As long as this cab is as good as it sounds, you could probaly pick it for around $100 and then just have to pick it up and bring it too me. Intersted?
Old 08-24-2004, 08:46 PM   #6
Joey-D
Joey-D's Avatar
Sorry I wasn't paying attention when I made that last post, I had found another cab in texas that the guy only wanted $125obo for. I ment to put in a hyperlink but my gf was bothering me at the time. Anyway that cab is gone. I really want a small back window cab, but anythings fine. If you really need the vin, I can sell it with the cab and title, but would rather not unless I had another one. I have about $250 in metal and hundreds of ours of time in the cab, so I figured I would get the least screwed by trading it. So one could probaly find another cab for far less than I would accept for this one. To sum it all up, make me an offer!
Old 08-24-2004, 11:28 PM   #7
firedog
firedog's Avatar
So Dirt Did We Cut That Cab Up For Nothing Here I Was Ready To See What You Were Going To Do With The Parts Good Luck
Give Me A Call Sometime Mike
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 08-28-2004, 03:34 PM   #8
Joey-D
Joey-D's Avatar
Im in over my head now, just want to start putting things back together, you know. I have those trim pieces sitting on my work bench along with a gazillion other things. When I have sometime I will run them down to you.
