08-20-2004, 04:37 PM | #1 |
Broke and still trying
A 422 Big Block
How can you make a 422 big block chev? Is it a 396 or 402 with an unconventional bore? I have a chance at it but don't want to get into something that I can't find pistons for. You help is greatly appreciated.
08-20-2004, 05:04 PM | #2 |
don't know ,but i know it's quite rude and a waste of space to post the same question on multiple boards
08-20-2004, 05:11 PM | #3 |
Apparently I found out which one gets more views. .
Relax Life's Too Short! |
08-20-2004, 05:14 PM | #4 |
why would you want to build this motor? pistons will almost definately be a custom made piston. a 427 or 454 would be much cheaper.
Anthony |
08-20-2004, 05:47 PM | #5 |
It must have started as a 396 I would guess or a 402. It has just been rebuilt. It currently has a stock bottom end but he may be willing to trade me for a sb that he needs to go into a vehicle to sell. I still need the casting numbers and crank number before I make my final decision. I was wondering if this may have been one of those .040 bores some people do. I need to run through the calculations to find out what it started as. I plan on doing a stroker but I need the base block to begin with. Just looking for insight.
08-20-2004, 06:41 PM | #6 |
GEARHEAD
Never heard of it. Could be the seller just has no real idea what he has.
HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
08-20-2004, 06:59 PM | #7 |
i think if you use a454 crank in a 396/402 block it comes up as a 427. i don`t know if the 454 crank will physically fit the 396/402 block due to the bigger stroke but i could be wrong. would still need custom pistonce since this isn`t a norman set up.
Anthony |
