Old 08-20-2004, 10:53 PM   #1
jpabberton
madcow
jpabberton's Avatar
Compression PSI
I checked the compression on my 1970 1/2 ton SWB 350-4 bolt today and every cylinder was between 120-130 psi. The manual states it should be 150 psi. My question is, should I rebuild or get a new long block, or leave it as is? The motor is a bit tired, and I'm getting ready to repaint it, so I'm debating if I should change it out before painting.
Any suggestions?
jpabberton is offline   Reply With Quote
Old 08-20-2004, 10:59 PM   #2
walker
walker's Avatar
That is not really bad compression numbers. Mkae sure you have a freshly charged battery, no sparkies in the block. Also do a oil squirt in the cylinder test to compare the numbers, it will also tell you if the rings are worn or the valves are shot. A little more work here will pay off in saving you money for work that you did'nt need to do.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-20-2004, 11:02 PM   #3
thisolechevy
yeah I would definetly not re-build if the numbers are that high, of course I have no clue what you are going to use it for, daily driver? street/strip?
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 08-20-2004, 11:05 PM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Did you test with the throtte wide open...it makes a big difference! Also crank about 3-5 compression strokes...I know you probably know this but I forget sometimes so I am only providing you a reminder here...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-20-2004, 11:05 PM   #5
crazy longhorn
Fabricate till you "puke"
one of the biggest factors in comp(cranking pressure), is that all cyls are within 10 % highest to lowest. it doesnt sound too bad from that standpoint. you could also have a loose timing chain, retarding the cam timing & also causing slightly lower cranking #, or if the eng was not warmed up, & throttle proped open during the test, the # will read a little low....just fruit for thought. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-21-2004, 06:00 PM   #6
jpabberton
madcow
jpabberton's Avatar
Thanks for the information.
The engine was cold when I did the test, and the throttle was not wide open. Do you have any idea what percentage difference +/- these two things make on average.? I assume that the PSI would go down, but by how much? 5-10% maybe?
Its not a daily driver.....I use it to go to Home Depot, kids baseball practice, etc. I can live with it this way if I can get away with it. Thanks for the help.
