Old 08-21-2004, 12:55 PM   #1
SnS C10
SnS C10's Avatar
brakes stopped working, what can be wrong?
on my way home last night my 72 gmc with disc and drums brakes wouldnt stop anymore. the pedal started to go all the way to the floor and if i pumped the pedal it made no difference and still went to the floor with barely any resistance. So i let it sit last night and checked it this morning. i checked the fluid and it is fine. then i did a vacuum leak test. i turned the engine on and let it idle for a minute or 2. then i shut it off. waited another minute and pressed the brakes pedal about 5 or 6 times. each time was the same and the pedal went to the floor. this is the procedure my manual said to do. so i guess there is a vacuum leak in the system. the hose for the power brake booster is perfectly fine. what can i check to fix this, what do u guys think the problem is? thanks
SnS C10 is offline   Reply With Quote
Old 08-21-2004, 01:12 PM   #2
69ride
All Go, No Show
69ride's Avatar
could it be the master cylinder bypassing inside? if the vacuum is fine I would crack a bleeder and see if the wheel cylinders are getting fluid.
69 LWB
Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI.
69ride is offline   Reply With Quote
Old 08-21-2004, 02:30 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Master cylinder leaking internally.
under 25 bucks at any parts store.
Old 08-21-2004, 02:47 PM   #4
ckhd
ckhd's Avatar
pedal to the floor with little to no braking is typically the master cylinder. Typically, if you pump it fast, it will pump up a little and slow you down. Went through it twice...
First on my '68, manual brakes, It would slow it down, a little. I intalled a new MC, and now when I stomp on the brakes, I can almost make the passenger hit his head on the dash... remember MANUAL brakes!
I went through the same thing on my '99 Suburban. The wife tells me that the brakes aren't working very good, so I go test it. Scared the crap out of me! Pedal hit the floor and I wasn't slowing down! Changed the MC and they work great.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-21-2004, 03:12 PM   #5
walker
walker's Avatar
Ditto, MC, $15.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-21-2004, 03:29 PM   #6
ryan68
Certified Chevy Man
ryan68's Avatar
Last time mine did that, both rear wheel cylinders were blown apart. Something to check, but most likely is the MC.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 08-21-2004, 04:17 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i just had that same problem, so i changed my master. went for a test, couldnt stop coming out of my driveway. bleed the front brakes and they still went to the floor. so then i changed all fluid front to rear with a niffty bleeder that hooks to your air compressor and sucked evey thing out. went down the road and was getting a 4 tire lock up.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 08-21-2004, 04:31 PM   #8
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Ever lose a master cylinder with the suicide single cylinder single line versions the pre 67 cars had? LOL, I had a 66 Malibu that did that and I about wrecked on the highway. Had to pump the pedal as fast and as hard as I could to stop, the piston had corroded enough to let some fluid go around it and would produce almost zero fluid pressure.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
