Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-21-2004, 08:19 PM   #1
thisolechevy
Exclamation OT: but need help with honda 8hp motor
Hi there I nknow this is off topic but everybody here is so helpful. The problem is I got a free honda 8hp gx-240 from my uncle because it was froze up. I took the head apart and unfroze the motor reassembled and ther was absolutly no compression what so ever. I then decided to re-build it and got it all assembled last night (new rings, piston top, gasket, pretty much everything) stupid me gets in a hurry when disassembling and I forgot to mark the gears in the block for re-installation sooo I just put it all back together where it looked right and nothing hit :-) I went to check everything before trying to crank and there is still no compression
whats up with that??? the "pcv" valveon the valve cover has lots of compression? where there is practically nothing coming from the exhaust or plug hole? what wrong with this motor.
I was wondering if the gear that ran the valves could be on backwards and creating compression in the place? is this possible? and also I tightened the vlave springs all the way down and tehn lossened them a full turn for lack of torc. wrench. will this do? or do I need to get one?
Sorry fo the long post but I am lost
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 08-21-2004, 08:31 PM   #2
Sweet72
Sweet72's Avatar
I've never done a honda engine, but a few briggs and tecumseh's, but it sounds like the valve timing is off. You should re-check the camshaft gear alignment. As for the valve adjustment, is this thing an overhead valve motor with rocker's and pushrods?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-21-2004, 09:17 PM   #3
thisolechevy
yes it is an overhead motor and has valve springs, pushrods, rockers, all the stuff a regular head has.
Old 08-22-2004, 09:53 PM   #4
thisolechevy
Ttt
