08-22-2004, 02:15 PM | #1 |
2wd lift ?
Does anyone know of a lift for the 2wd 1\2 ton? I know of a 78 Blazer 2wd 4spd that a would like to have IF I could put 33 inch tires on.
] : - 71' burb,5.3,4wd 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
08-22-2004, 04:35 PM | #2 |
If it was me I would Just buy a 4X4.... They are alot cheaper and easier to find right now.
The 2WDs are going up in value. Either way I am sure you could lift it pretty easily. Research some of the suspension sites under links. |
08-22-2004, 09:17 PM | #3 |
You can get 33's on it with fiberglass fenders and no lift in fact you can get 35's on it.
http://www.mkparker.com/goose/ Check out that site. It has some info about fenders on it.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-22-2004, 10:39 PM | #4 |
Go to fabtechmotorsports.com they have a very nice long travel two wheel drive kit for this model. Looks sharp and handles well I have heard. Good luck
08-24-2004, 05:22 PM | #5 |
you could do a few things...
add lift coils, they make 3" lift coils.. add coils spacers.. a 3/4" spacer will give you a couple inches of lift. rear lift is easy, shackle flip, or new springs (best way) or blocks (cheapest way). i run 32" tires with no rubbing, i do have HD coils springs so my truck has 0 rake.. sits level.. and i rolled the top lip of the fender, but it is so slight you cant even tell unless you look close. rolled it just enough to keep it from slicing up the tires like it was doing. feel free to message me if you need more info...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
08-25-2004, 12:52 PM | #6 |
Nightrider, if you don't buy it. let me know how much it is? I would slam it!
08-25-2004, 06:17 PM | #7 |
It followed me home?
I saw a link on ck5.com that showed superlift ebay store scratch and dent 2wd lift coils for like $60 if that helps? I would have posted a link but I cant seem to get ck5.com to work right now. Its in the for sale board if you are interested
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-25-2004, 10:15 PM | #8 |
08-26-2004, 08:18 AM | #9 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
08-26-2004, 12:49 PM | #10 |
i dont know about 10" wheels with 4" BS... my 32x11.50s on 8" wheel (not sure about BS) only barely rubbed until i rolled the fenders.. any wider and they would probably rub the lower part of the fenders.. here is a pic of my 32s this is with the wheel straight.. when turning there is less than 2 fingers width between tire and lower part of the fender..
