08-22-2004, 10:04 PM | #1 |
Drip Rail sealer question.
What sealer are you guys using to fill in the drip rail when you repaint your trucks? I've stripped my truck down to the metal, even remove the cracked old sealer in the drip rail. Now I need to put new sealer in.
Thanks in advance. Scott |
08-22-2004, 11:23 PM | #2 |
3M self-leveling seam sealer, a two part sealer. You will need a special gun to dispense it, real cheap tho. Mask around both sides of seam after priming, fill drip rail, let set, paint. Brian
08-23-2004, 07:11 AM | #3 |
Almost done!
3M drip check. Made for drip rails, hence the name. It dries overnight and is paintable. No special tools needed, just a steady hand...
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
08-23-2004, 10:48 AM | #4 |
drip rail sealer
I used Drip chek and it worked great. I emailed #M and thats what they said to use.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
08-23-2004, 10:59 AM | #5 |
Thanks for the suggestions guys. Looks like I'll go and get some drip check. Mixup, how many tubes did you use?
Thanks, Scott |
08-23-2004, 11:31 AM | #6 |
drip rail sealer
It took just about 2 tubes but I got 3 just in case.
