Old 08-23-2004, 12:10 AM   #1
skokie
skokie's Avatar
What size Carb?
What size carb can out on a 68 1/2 ton with a 327? Was it 600 or 750?
skokie is offline   Reply With Quote
Old 08-23-2004, 09:46 AM   #2
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Pretty sure the '69 C20 327 I played with in high school had a Quadrajet, and I think they're rated at 780 CFM.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-23-2004, 10:02 AM   #3
RAT-AT-TACH
RAT-AT-TACH's Avatar
i think a 780 might be a litlle much it would just dump the fuel in i would go for a 650 and make sure the spacer is the right hight for your mixture.
jmo
who says moneys not everything....try running a rat!
RAT-AT-TACH is offline   Reply With Quote
Old 08-23-2004, 02:42 PM   #4
Bowtie67
Bowtie67's Avatar
You really dont want more than a 600cfm with an aftermarket carb like a Edlejunk or Holley, etc unless it is built for severe performance and the same 600cfm will also work well on a fairly built 350. Quadrajets have many ratings not just one, most 327's had either a 2 barrel or quadrajet carb, I have seen them rated from 675 up to 825cfms. And if anyone is building performance dont use a Edlebrock go for the Holley, Demon or Quadrajet setups. The Edlebrock carbs are not meant for performance they are ment to be emission friendly and will fall short on a tre HiPerformance engine build.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
