Old 08-23-2004, 10:57 AM   #1
Bram
Broke
Bram's Avatar
Question Intermittent wipers
I know this has been discussed before, but without the search option I can't find it.
Does anyone know if there is an aftermarket controller the will work with our trucks?
Or is there anything else available?
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 08-23-2004, 11:19 AM   #2
smokekiki
Mike
smokekiki's Avatar
jc whitney has a couple types.Check with street rod suppliers.I have a few catologs I can look at when I get home.also this link might help update on intermittent wipers
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-23-2004, 11:20 AM   #3
smokekiki
Mike
smokekiki's Avatar
Forgot to post link http://67-72chevytrucks.com/vboard/s...d.php3?t=32017
Old 08-23-2004, 11:32 AM   #4
cdowns
cdowns's Avatar
i used a switch and controller from mid70's pinto ,it works great and was able to use the original bezal and knob so you can't tell it's not stock
Old 08-23-2004, 12:32 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
cdowns, was there any wiring issues or just a straight simple swap?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-23-2004, 02:05 PM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
cdowns, could you please post more details? Pictures?
Is the "brain box" the same part as the switch so it is all mounted behind the dash in the stock location? What about wiring?
badpeanut is offline   Reply With Quote
Old 08-23-2004, 02:15 PM   #7
cdowns
cdowns's Avatar
in regard to the wiring it wasn't a real big deal when i did it5years ago, i just had to do it by trial and error till i got it right. no the brain box was seperate from the switch and i mounted it up by the firewall. as far as pictures it's up under the dash and with the ac hoses up there it really can't be seen
Old 08-24-2004, 08:40 AM   #8
Bram
Broke
Bram's Avatar
Btt
