Old 08-23-2004, 12:21 PM   #1
CHEVYJEFF
CHEVYJEFF's Avatar
bump steer ?'s
Looking for ideas for curing my bump steer issue. after doing my 4" tci lift and adding my 35" bfg all terrains and steel wheels, I notice I have a pretty good case of the bump steer. When the truck hits a bump going while going straight the wheels seem to move the steering wheel really hard. The truck will go straight when hitting bumps but the steering wheel jerks left and right. Everything is new on the front axil and suspension. I installed a dual stabilizer and it helped but it seems to be doing it worse again. I was thinking about doing two things to help the bump steer. One is adding a drop pitman arm to go along with the raised steering arm already on the truck, the second is to install another shock on each side on front as it came from factory (quad shock) (only used one shock per side front when I did the lift) Only other thing I can think is the steering box is tired but there isnt much slop in it either.
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 08-23-2004, 12:51 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Crossover steering the pretty much your best bet. I'm surprised your bump-steer is that bad. Mine is not that bad at all and I have 38's.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 08-23-2004, 12:52 PM   #3
CHEVYJEFF
CHEVYJEFF's Avatar
it is just kind of annoying. I am thinking it may be steering box related
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 08-23-2004, 01:58 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Box could be tight but not tight to the frame, make sure it is tight to the frame. Dropping the pitman arm might actually aggrevate the condition as the drag link needs to be as level(front to back) as possible.
Cross-over would be the way to go.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-24-2004, 12:10 AM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Also check for cracks in the frame at the steering gear mounting area.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 08-24-2004, 12:50 AM   #6
'71k-10
off road design (offroaddesign.com) has crossover steering for dana 44, 10 bolt and dana 60 front ends, if you decide to go that way. just a thought.
'71k-10 is offline   Reply With Quote
Old 08-24-2004, 09:05 AM   #7
CHEVYJEFF
CHEVYJEFF's Avatar
I recheckedeverything under the front end including frame and steering box tightness. All is nice and tight. is it possible that the powersteering pump does not have enough pressure to keep the steering box from being moved by the drag and center link? I have heard of guys drilling out the hole in the ps pump in hydraulic steering set ups but for more pressure. Im curions if I put a smaller return line on the pump if it would make the steering box harder to move thus making it harder for the axil assembly to manipulate the steering box.
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 08-24-2004, 10:32 AM   #8
cochino12
It followed me home?
cochino12's Avatar
I had no problem with 4" and 35"s and then I added the raised steering arm and its doing exactly as you described. I have heard that sometimes the arm is too tall for a 4" lift and it causes the bumpsteer. I think I might just get the weld in brace for steering box and switch back to the stock steering arm?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-24-2004, 11:57 AM   #9
CHEVYJEFF
CHEVYJEFF's Avatar
thats a new one on me, never heard of the arm being to tall for a 4" lift. I know that the drag link is supossed to be horizontal with the ground at ride hieght. hmmmmm very interesting will check that next. I sure dont want to try and take that damn arm off.
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 08-24-2004, 07:53 PM   #10
Joey-D
City's Articulation Ramp
Joey-D's Avatar
I have 8" lift and 38.5s and had horrible bumpsteer. I went with crossover steering from blackbirds customs and "OH MY GOD IS IT A DIFFERENCE!!" I never thought with 38s I could let go of the wheel and it track straight. No more bumpsteer at all. And above all that, my turning radius is now literally 50% of what it used to be. Granted my old drag linkages was worn out, but there were times with that set up I could catch a rut, the wheels turned to the left and max out the steering wheel to the right. It would all just bind up. I also installed one hechithorn heavy duty steering stabalizer from JC Whitney. I think I spent $450 for the kit, minus the 2wd drive steering box (Which I stole from the 69 project). It seems like a hell of a lot of money for only a couple parts, but it was worth every dime of it. I can't praise crossover enough.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 09-17-2004, 10:09 AM   #11
poff
I had the same problem with my lift. From what I can tell it is about 4". The truck had a 4" steering arm when I got it and it had bad bump steer. I put a stock arm with a 2" drop pitman arm and the bump steer is almost completely gone. Of coarse a little bump steer is always there because of the design. Crossover is definitely the best way to go. I am waiting 'till I get a Dana 60 to do it though. Too much work to do the D44. Check the rag joint too.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 09-17-2004, 10:23 AM   #12
CHEVYJEFF
CHEVYJEFF's Avatar
Think I am going to try this. I had some other people tell me that a dropped pitman arm and stock steering arm fixed thier problem. Let you know what I find.
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 09-17-2004, 10:28 AM   #13
poff
The only company I found that made one is Skyjacker, cost me about $100. 4WheelParts price matched Summit. Hint: Summit does not list everything online that they sell in thier catalog. If you do "Manufacturer Search" and enter the manufacturers part # you can find parts that are not listed otherwise, got GM Performance parts cheap this way.
Old 09-17-2004, 11:06 AM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I bought the 2" drop pitman arm for my 70 from ORD, it was under $100.
Old 10-11-2004, 10:05 AM   #15
CHEVYJEFF
CHEVYJEFF's Avatar
Update
I installed the 2" drop pitman arm (skyjacker ca-90) and stock steering arm over the weekend and it got rid of 95% of my bumpsteer problems. The truck is easier to steer and doesnt jerk the wheel at all. The draglink length was reduced by about 1-2" and ride is so much better. Now just need to find a buyer for one slightly used 4" raised steering arm.
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 10-11-2004, 10:30 AM   #16
cochino12
cochino12's Avatar
thats what I was going to do also, but I found a good deal on some x-over stuff. Glad it worked out for you.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-11-2004, 11:20 PM   #17
'71c204x4454
'71k204x4454
since some of you brought up cross-over steering and sound like some of you have it was wondering if it would fit on a '71 with just a 2" lift. I like the idea of tighter turning radius.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 10-12-2004, 10:27 AM   #18
CHEVYJEFF
CHEVYJEFF's Avatar
I dont know how crossover steering would fit on anything else but a 6" and up lift and still keep the sway bar. But it is by far the best solution to the b.s. issue
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 10-12-2004, 11:31 AM   #19
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I have always heard that cross-over works for 6" lifts or more.
Check your rag joint to see if it is worn. You may want to replace it too. Also, check your tire pressure. I have heard different brands of tires can solve the problem too, especially on your combo. My '69 has 6" lift and 35's and bump steer is minimal. My old '72 had a 4" lift and 35's with no bump steer. My current '72 has a 4" lift with stock wheels and tires and drives straight as an arrow.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-12-2004, 02:58 PM   #20
Joey-D
Joey-D's Avatar
I know on lifts of 4" or less there is a problem with the draglink hitting the engine/frame crossmember. People have modified there crossmember and some have even started selling new crossmembers they have made. Private individuals that is. I read about it on either this forum, coloradok5.com or pirate4x4.com. I was worried about my draglinkage too, but BlackBirds told me I would have no problems because of my drop pitman arm. Though with only 2" of lift, there would be a need for a drop pitman arm, so a crossmember could be an issue. Also look at crossover as though it was SBC Heads. Buy them too big. That first motor will be bad, then you get used to it and want more horsepower. If you bought heads that were too big for that motor, making it bigger and badder will be cheaper and easier. 2" of lift is good now, but when you decide its too small and want 6" or even 12", you will already be ahead of the game!
Old 10-12-2004, 03:08 PM   #21
cochino12
cochino12's Avatar
Looks like I am actually going to change direction again, since mine is a DD. I am going to sell this x-over stuff and buy a drop pittman arm. Only reason I wanted it was to cure bumpsteer anyway. So if anyone is interested I will have x-over for a 10bolt for sale by the end of the week.
adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-12-2004, 03:28 PM   #22
CHEVYJEFF
CHEVYJEFF's Avatar
adam
I know the feeling. you should have no problem selling that stuff. Remeber you will need the stock steering arm with the drop pitman arm. On a positive note the steering arm was much easier to take off than the first time. It took me about an hour and 4 beers. Then I killed the rest of the 12 pack installing those rancho kicker shocks that i should have passed on.
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 10-12-2004, 04:45 PM   #23
cochino12
cochino12's Avatar
Hey Jeff, maybe I missed it but what did you pay for the pitman arm? Cheapest I have found is $85. thanks
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-12-2004, 05:27 PM   #24
CHEVYJEFF
CHEVYJEFF's Avatar
90 - 100 plus shipping is what i found too. skyjacker (ca-90) is about the only one that makes it. I lucked out and found someone on ck5 that sold me a used one and a stock steering arm for 60
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 11-11-2004, 12:19 PM   #25
eskyblaze
eskyblaze's Avatar
Crossover steering
Is your crossover steering setup interchangable with a Dana 44 and if so how much? Also how and where can I get in touch with blackbird customs.
1970 Blazer/383 stroker
700R4/NP208
Duel Electric Fans
140 amp alt
Old air AC (awesome)
Truetrac rear and 410's
Leather Buckets and rhino inside
eskyblaze is offline   Reply With Quote
