Old 08-23-2004, 04:24 PM   #1
Z28Owner
Z28Owner's Avatar
Need help with edelbrock carb please!!
Ok I have had this carb for a couple years. Its a 1405 manual choke 600cfm. Anyways I wanted to install electric choke for this winter. Well everything ran fine before, I removed carb and installed edelbrock's electric choke kit and didnt have any spare parts leftover and everything went pretty smooth. So I get it all hooked back up and turn it over for a bit to get fuel back in the carb and it isnt starting. So I double check the fuel and see it spraying down in there and still, nothing. So I held the butterfly open and closed and cant get it to start at all? What could be causing this? Help please!!! Thanks.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 08-23-2004, 04:28 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
If you got fuel , check for spark. Back to basics
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 08-23-2004, 05:19 PM   #3
cdowns
cdowns's Avatar
check distrib to see if the wires are still hooked up
Old 08-23-2004, 10:57 PM   #4
walker
walker's Avatar
I'd say hei wire pulled out. At least that is what happened when I did it . Might also check to make sure your big vaccum line in the back are plugged. May have bumped the dizzy a little out of time, or coil connection came off.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
